flowgoode Posted June 29, 2016 Share Posted June 29, 2016 Precision 6266 .81 A/R T4 single scroll @ 17psi. Stock motor, stock cams. I'm hoping when I put my HKS Step 1 272 cams in it, will make a little bit of difference with spool up. Link to comment https://www.sau.com.au/forums/topic/465548-dynod-my-single-turbo-r32-gtr-video/ Share on other sites More sharing options...
KiwiRS4T Posted June 29, 2016 Share Posted June 29, 2016 Less chat more boost!! Link to comment https://www.sau.com.au/forums/topic/465548-dynod-my-single-turbo-r32-gtr-video/#findComment-7752636 Share on other sites More sharing options...
Dose Pipe Sutututu Posted June 29, 2016 Share Posted June 29, 2016 Yeah it will make a difference, it's called more lag with longer duration cams Link to comment https://www.sau.com.au/forums/topic/465548-dynod-my-single-turbo-r32-gtr-video/#findComment-7752647 Share on other sites More sharing options...
flowgoode Posted June 29, 2016 Author Share Posted June 29, 2016 Less chat more boost!! hahaha, yeah. I will do that after I upgrade headbolts. Yeah it will make a difference, it's called more lag with longer duration cams Is that actually always true? Wouldn't longer duration exhaust cam let out more exhaust flow to spool the turbo faster? Or would having more duration intake and more duration exhaust just equal out and have me where I currently sit as far as lag is concerned? Link to comment https://www.sau.com.au/forums/topic/465548-dynod-my-single-turbo-r32-gtr-video/#findComment-7752697 Share on other sites More sharing options...
KiwiRS4T Posted June 29, 2016 Share Posted June 29, 2016 Longer opening of the exhaust means it takes longer to build up the compression. Comes into its own at high revs. Link to comment https://www.sau.com.au/forums/topic/465548-dynod-my-single-turbo-r32-gtr-video/#findComment-7752700 Share on other sites More sharing options...
Dose Pipe Sutututu Posted June 29, 2016 Share Posted June 29, 2016 Yes, always true. Your essentially shifting the motor's efficiency to the right. Whoever recommended you longer duration cams for response should go read a few text books and educate themselves (saying that very nicely). You want some more response, I suggest going to a twin scroll setup, ie divided housing, proper twin scroll manifold, twin gates. Link to comment https://www.sau.com.au/forums/topic/465548-dynod-my-single-turbo-r32-gtr-video/#findComment-7752729 Share on other sites More sharing options...
flowgoode Posted June 30, 2016 Author Share Posted June 30, 2016 Yes, always true. Your essentially shifting the motor's efficiency to the right. Whoever recommended you longer duration cams for response should go read a few text books and educate themselves (saying that very nicely). You want some more response, I suggest going to a twin scroll setup, ie divided housing, proper twin scroll manifold, twin gates. No one recommended me longer duration for response. I bought the cams before going single turbo. So I have them to put in still. Looks like I'll be looking for a twin scroll setup in the future...or stroker kit lol Link to comment https://www.sau.com.au/forums/topic/465548-dynod-my-single-turbo-r32-gtr-video/#findComment-7752837 Share on other sites More sharing options...
Dose Pipe Sutututu Posted June 30, 2016 Share Posted June 30, 2016 yeah sell the cams, spend the money on doing a proper TS setup... much more gains there.. and more boost.. don't be a pussy Link to comment https://www.sau.com.au/forums/topic/465548-dynod-my-single-turbo-r32-gtr-video/#findComment-7752841 Share on other sites More sharing options...
XGTRX Posted July 1, 2016 Share Posted July 1, 2016 No one recommended me longer duration for response. I bought the cams before going single turbo. So I have them to put in still. Looks like I'll be looking for a twin scroll setup in the future...or stroker kit lol Put the cams in and boost it. Get that face stretch going. Link to comment https://www.sau.com.au/forums/topic/465548-dynod-my-single-turbo-r32-gtr-video/#findComment-7753182 Share on other sites More sharing options...
HarrisRacing Posted July 5, 2016 Share Posted July 5, 2016 I saw your dyno. I'm on Tomei Poncam A's with the 260 duration intake and 252 duration exhaust on a stroker motor with divided exhaust housing on BW 8374 EFR IWG .92 housing and I am seeing full boost in 4th gear around 3600 rpms, but full boost in 3rd right at 4k. I'm spinning to 8k rpms and 17 psi is 464 whp and 371 ft-lbs toqrue.If you look at Tomei's website about their stroker kit, my horsepower numbers follow their dyno almost exactly with a 20% addition in power (converting to flywheel from wheel HP). If you notice, there appears to be about a 400 rpm shift to the left from going to a stroker with a bit more top end due to increased displacement. I'd say your numbers are on target to be honest. We both need to apply more boost and/or move to E85 (which will definitely be my next step - give me a couple of months). I'm still trying for 500 whp on pump gas which should be possible up around 19-20 psi and I would bet it would hit 400 wtq there as well. Also it should be noted that if I were to go for total streetable HP ON 93 PUMPGAS on a RB26 with stock cams, I would go smaller than 62mm turbo chargers - I would pick something in the high 50mm...like BW 7670 or in your case 5862. These will all have a better powerband and will make the car more usable on the street if less than 20 psi boost. The 7670 would be insanely fast and responsive. I was going to go there, but when the stroker decision was made, i scrapped it for 8374. Again, you'll be limited to 8k or less rpms and likely 20 psi or less, but you'll have better powerband for sure. I have attached my graph, I'd like to compare the two if you have a printout of yours (or could put it in the attached excel spreadsheet). dyno converted.xlsx Link to comment https://www.sau.com.au/forums/topic/465548-dynod-my-single-turbo-r32-gtr-video/#findComment-7754554 Share on other sites More sharing options...
Dose Pipe Sutututu Posted July 6, 2016 Share Posted July 6, 2016 Put stock cams in, add more boost instant response/power It's not an Evo/4G63T, no need for 272 brap cams. Link to comment https://www.sau.com.au/forums/topic/465548-dynod-my-single-turbo-r32-gtr-video/#findComment-7754876 Share on other sites More sharing options...
Hadouken Posted July 6, 2016 Share Posted July 6, 2016 lies Link to comment https://www.sau.com.au/forums/topic/465548-dynod-my-single-turbo-r32-gtr-video/#findComment-7754900 Share on other sites More sharing options...
XGTRX Posted July 6, 2016 Share Posted July 6, 2016 Massive cams, big lump, curve all the way to the right = face stretch fun = perfect setup. Put those cams in man Link to comment https://www.sau.com.au/forums/topic/465548-dynod-my-single-turbo-r32-gtr-video/#findComment-7754903 Share on other sites More sharing options...
niZmO_Man Posted July 6, 2016 Share Posted July 6, 2016 Do it 1 Link to comment https://www.sau.com.au/forums/topic/465548-dynod-my-single-turbo-r32-gtr-video/#findComment-7754911 Share on other sites More sharing options...
HarrisRacing Posted July 6, 2016 Share Posted July 6, 2016 Heck mine with stroker and the small Tomei cams kind of lopes, but that one above is MUCH AWESOMER. Check the 35 sec mark. Link to comment https://www.sau.com.au/forums/topic/465548-dynod-my-single-turbo-r32-gtr-video/#findComment-7755057 Share on other sites More sharing options...
