2016 Round 6 Winton - Saturday 13th August Hosted By Circuit Club
13512105_1383216878371351_74933365472289
After the success of the 2015 Circuit Club day at Winton we thought it would be great so join them again. There will be passenger sessions throughout the day
- For anyone interested in attending their first track day here all you need to know : http://www.sau.com.a...y-requirements/
Licence:
You will need a CAMS or AASA licence to compete on the day.
L2S can be obtained via https://www.cams.com.au/
You can purchase a AASA day licence at the track for $TBA (good idea if this is the only track day you are doing this year)
Other requirements : http://www.sau.com.a...y-requirements/
Winton Motor Raceway
Fox Street, Winton
https://goo.gl/maps/wWhJVKs4aJv
Pricing:
$230 per driver
$80 per second driver
$35 per passenger
Spectators: Free
Entry/Registration
http://circuitclub.com.au/event/82
Squires Loft Nunawading will be putting on lunch for all SAU VIC members (Comment in this thread if you are attending so we can cater accordingly).
12814196_1283609094998797_25854580291215
  • Like 2
Great,
I am hoping to use this as a shakedown before bathurst at the end of the year.
I also hear we might have a special S14 production car make it's first appearance in about 10 years!
  • Like 2
6 minutes ago, acsplit said:
Hey Josh
I will find out about passenger/ instructor sessions the guys are circuit club are usually very flexible so I would say so.
Thanks Andrew. If I could be his instructor that would be perfect.
Ok guys,
Waiting on hearing back on instructor sessions but I have heard a few guys who have been sidelined most of the year are coming out for this one.
Also sneak peak of a car that has not turned a wheel at the track in over 10 years and should make it's shakedown at Winton.
13653370_1410901292269576_66821806346019
On 29 June 2016 at 8:14 PM, phantc_s15 said:
Awesome! Hope to get the s14 to this!
I'll be there but not driving (the old man is driving).
So if anyone would like some coaching I will be more than happy to help.
  • Like 2
Would def be interested in some coaching too!
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
