13 hours ago, darcyy said:
Yes, But they only work on Aus delivered nissans!
Locksmith couldn't reprogram it because the CEL is not working
Do you have another dealership you can go to?
Most Nissan dealerships will work on imports
On 7/5/2016 at 6:52 AM, KiwiRS4T said:
What about a non-franchise shop that works on Nissans and has a Consult tool?
None want anything to do with it.
Just had it on a scan tool, body control module code is coming up. Is nissan the only place to get it re-coded?
Mate of mine had to have his V35 BCM replaced which obviously meant re-coding.
It was a 30 minute job - replace and re-code at Nissan.
As far as I know, yes, only at Nissan but then I am unfamiliar with most scan tools. Maybe ask around if anyone local has Snap-on or a Consult 3/4. Consult will do the job, but unsure as to the Snap-on.
Also, where are you located?
Sorry for the late reply!
Did his require a brand new BCM or would a used one work as well?
Had a locksmith try to recode it but couldn't due to the check engine light not working,
Im northside brisbane
New BCM as his was stuffed.
Quoted from his text message:
"cost was $300 and something + fitting. Can't remember price, but wasn't too bad for fitting as it is all plug in shit and easy for them to program with consult"
He had Ferntree Gull Nissan (VIC) do the lot. Maybe you need to find a competent Nissan dealership or at least a mech with access to consult?
ok will swap in a new BCM and take it to nissan to get re-coded
Thanks for the help
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
