13 hours ago, darcyy said:
Yes, But they only work on Aus delivered nissans!
Locksmith couldn't reprogram it because the CEL is not working
Do you have another dealership you can go to?
Most Nissan dealerships will work on imports
On 7/5/2016 at 6:52 AM, KiwiRS4T said:
What about a non-franchise shop that works on Nissans and has a Consult tool?
None want anything to do with it.
Just had it on a scan tool, body control module code is coming up. Is nissan the only place to get it re-coded?
Mate of mine had to have his V35 BCM replaced which obviously meant re-coding.
It was a 30 minute job - replace and re-code at Nissan.
As far as I know, yes, only at Nissan but then I am unfamiliar with most scan tools. Maybe ask around if anyone local has Snap-on or a Consult 3/4. Consult will do the job, but unsure as to the Snap-on.
Also, where are you located?
Sorry for the late reply!
Did his require a brand new BCM or would a used one work as well?
Had a locksmith try to recode it but couldn't due to the check engine light not working,
Im northside brisbane
New BCM as his was stuffed.
Quoted from his text message:
"cost was $300 and something + fitting. Can't remember price, but wasn't too bad for fitting as it is all plug in shit and easy for them to program with consult"
He had Ferntree Gull Nissan (VIC) do the lot. Maybe you need to find a competent Nissan dealership or at least a mech with access to consult?
ok will swap in a new BCM and take it to nissan to get re-coded
Thanks for the help
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
