1998 R34 GT-T Sedan (running on E85) 136xxxkms
Factory Manual
Factory Sunroof
Factory Nismo Kit
Engine out full body silver re-spray
Rays TE37SL 18 x 9.5 +22
Engine fully detailed and all clips and fixing replaced with new from Nissan
RB25DETNEO with RB26 Rocker and timing belt covers painted candy red
Head reworked by head torque, including seals, valves and Tomei spec 2 Camshafts
ARP head studs and cometic triple layer head gasket
NPC Carbon single plate clutch with custom lightened flywheel
Garret GTX 3076R Turbo highly polished on high mount Greedy copy manifold
Turbosmart 50mm external gate with Screamer
Genuine Greedy Plenum, highly polished with polished hyper tune fuel rail( twin entry)
1000cc Xpurt injectors with 200series fuel lines
Full custom stainless piping and exhaust, highly polished done by Sanders Racing
Varex muffler
Full braided lines throughout, all brand new and all speedflow
All factory options remain intake including traction control and air conditioning, all working 100%
Power FC with Z32 hidden on intake side under bumper
HKS EVC boost controller
Standard gauges replaced with DEFI gauges (Water temp, oil temp, boost)
All wiring in engine bay hidden in guards
Battery relocated to boot
Bride Low max reclinable front seats with carbon backs
Full Bride retrim to door panels, rear seat and console
Alpine head unit
Kenwood splits front and rear
Tein coilovers, with adjustable caster rods and camber arms
RDA dimpled and slotted all round, EBC Red brake pads and HELS braided lines
Car was tuned by ProTune before I got it and made 502hp@20psi with E85
NO SWAPS!
$22k
Please contact to meet for inspection, no test pilots, confirmed $$ required for test drive.
  • Like 1
  • 1 month later...
  • 2 months later...
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
