For sale is my Beloved 2001 series 2 GTT with 90000kms
This is a very regretful sale but i need the money for a house.
All the work has been carried out whilst I was the owner, when i received it from Japan it was completely stock.
Has been serviced every 5k since i got it at 49000 from japan. with spark plugs replaced every 10k.
It has been tuned at unigroup engineering with 300KW at 20psi. Too much money spent over the years to keep track
Has 11months rego.
No expenses have been spared
Looking for 30k ono
Body:
Nismo smoked front and side indicators
full respray only 6months old Bayside blue with 5% candy
Full GTR Body conversion
Rear quarters are genuine GTR, had them cut off and welded on, had the lips folded and fibreglassed up so theyre flush
R34 GTR front end conversion, all genuine parts were used besides the bonnet
GTR alloy guards
GTR front bumper with grills
GTR carbon fibre non genuine bonnet
Gtr skirts
GTR rear bumper
Tein gas bonnet struts
Nismo LED Tail lights
LED reverse lights
Suspension:
Project Mu hand brake pads
Project Mu wheel nuts
DBA 400 series T3 slotted rotors front and rear
GTR Strut Brace
White line heavy duty sway bars front and rear
BC racing coilover height and dampening adjustable suspension
Rear hicas lock bar installed
Modified Front knuckles for extra lock. Havnt quite finished with the geometry as wheels just rub the sway bar at full lock
GKtech series 2 front caster arms
Wheels are rota grid
Front    18x9.5 +18 5X114.3 Gloss Black
Back    18x10 +15 5X114.3 Gloss Black
Performance:
heavy duty 5puc button clutch
6Boost twin scroll t3 high mount exhaust manifold
Super responsive High mount garret setup
Plazmaman Intercooler powder coated black
Plazmaman Plenum and 3" throttle body powder coated black
Twin catch cans
Nismo in tank high flow fuel pump
Sard 650cc fuel injectors
Plazmaman Fuel Rail
Turbosmart FPR1200 fuel pressure regulator
Tial BOV with 10psi spring so flutters down low are return flow up high
Splitfire coil packs
GTR engine covers painted and modified to fit over VCT
72degree thermostat (had a nismo but was running too cold)
Genuine Koyo full aluminium Radiator
Garrett GTX3071r with 0.82 twin scroll external gates
Tial twin external wastegates with 16psi springs (true twin scroll), both plumbed back into exhaust
Setrab Oil cooler with greddy thermostatic sandwich plate
Magnetic sump plug
Apexi Pod filter in custom air box
Z32 Air flow metre
Shortened Shifter
Full custom 3.5" exhaust with 5" 100cell cat one muffler and then twin pipes tip
Electronics:
GTR MFD Installed
HKS EVC 6 electronic boost controller
HKS turbo timer
Apexi Power FC with hand controller in glove box
AEM failsafe air/Fuel Ratio Wideband and boost in one guage
3 Point immobiliser rhino alarm
Inside:
Recaro SR3 trail version seats.
GTR rear seat with carbon looking cover
Carbon dipped trims including shifter surround and window switch surrounds
Nismo floor mats
GTR rear foam boot tray
Pioneer dvd player with ipod control cable in glove box
Rockford Fosgate full system includes
Splits front and rear
2x amps one for sub and one for speakers
T2 rockford fosgate subwoofer in custom fibreglass enclosure
Capacitor to keep the sound up with heavy bass
https://www.sau.com.au/forums/topic/465676-r34-gtt-gtr/
1 minute ago, Selleck 34GTT said:
yeah it was, my mate dean pulver use to own the shop at the time
Yeah, I remember going in a few times to chat with Dean about my own car and noticing yours up the back there. Turned out quite nice! Good luck with sale.
Edited by jmknights93
https://www.sau.com.au/forums/topic/465676-r34-gtt-gtr/#findComment-7755259
sure did, thanks mate
https://www.sau.com.au/forums/topic/465676-r34-gtt-gtr/#findComment-7755262
16 hours ago, kolaxjason said:
Is all the mfd functions working?
How'd you go with wiring it in ect
Hey mate yeah it all works perfectly. Only things I hadn't yet hooked up were exhaust and intake temps as gtts don't have those sensors, I did run the wires but never got around to buying the sensors. My email is [email protected] flick me an email and I'll see if I can find all the diagrams I worked off
https://www.sau.com.au/forums/topic/465676-r34-gtt-gtr/#findComment-7755864
Thanks man, I'll contact you in the morning
https://www.sau.com.au/forums/topic/465676-r34-gtt-gtr/#findComment-7755908
  • 3 weeks later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
