Bonnet & hinges
Both headlights
Front Bar & support
Front bar fog lights both sides
Rad  Support
Radiator (suit automatic ),  Radiator Fan, schroud, cooling fan
Air con condenser
Probably more items required, don't know the names of other items around the rad support / bonnet section but would prefer to buy front section but open to all options.
Possibly crash sensor & crash CPU and driver's side & passenger airbags / seat belts. Prob best to buy entire dash but want above items first.
MUST BE SERIES II & MATCH - AUTOMATIC.  ........it's a 1997 40th Anniversary Series II model so not sure if there was anything different styling.
Photos pre and post accident to see if the parts you have match
PM me if anyone can help out
Cheers
Edited by mercyseat
Ripped off the front bar and under guards today.
Gonna need to get the chassis looked at on one side.
Nothing twisted underneath at all, both front side quarter panels are straight not buckled, nothing wrong with steering,  no engine or gearbox leaks.
Engine reinforced assembly bar is rooted, gonna need an angle grinder to get the last bolt on each side off. Can't get to anything else til its off as it's pushed everything on the rad support to the engine's timing case.
Radiator is stuffed, top tank cracked so no hope there.
Passenger airbag won't close so I may need a dash if this is true, not sure how to dismantle the airbags.
SB98U97Y071097 passenger air bag
Driver's airbag RB761978251031C
Want to make sure the chassis is fully repairable before going any further  at this point.
UPDATED LISTING OF PARTS REQUIRED
Pretty much everything from the Rad Support forward requires replacing.
Engine is OK, Auto Transmission OK, Chassis OK
So I require...
Bonnet (bonnet hinges are ok)
Rad Support
Headlight Support
Transmission Cooler
Front Bar Reinforced Bar
Radiator / Top Tank
Radiator Fan & Shroud Assembly
AC Condenser + accessories
AC Compressor + pully
Head Lights BOTH sides
Series II Front Bar including Fog Lights etc
Bonnet support / lock piece
And I require an entire dash including passenger + drivers airbags
Clock Spring
Even a 1997 Series 2 automatic wrecked, unregistered car I'm willing to purchase.
cheers
PM ME
Add to the list courtesy of Pickles forklifts they've damaged my rear suspension and gutter rashed the insides of front two rims....
Found Front Bar and Fog Lights
Plus Passenger LH headlight.
AC compressor looks ok it's the power steering & pully that took the hit, including the engine fan that sits in front of the water pump.
White fan ok but housing destroyed. Engine looks good.
AC condenser obliterated, radiator obliterated.
Edited by mercyseat
After a huge chat with VIC Roads I finally got the correct answer about repairing my vehicle.
It now doesn't require a VIV inspection, only has to be repaired and pass a full roadworthy.
So I've taken the car back off the For Sale thread and now require the below parts:
So what I require is.
NOSE CUT:
A  Nissan Skyline R33 Series II Coupe automatic (pref 1997) NOSE CUT including headlights, bumper, bumper reo, radiator, AC condenser, Transmission cooler
the lot all in one piece. No bits and pieces from here and there. Matching my Nismo front bar will probably be impossible but trying to buy everything in one hit.
Airbag Requirements:
Also need and MUST be from a 1997 Series II a dash pad including the passenger airbag and a Drivers airbag including clock spring and ECU. These parts MUST all be off the same car, no exceptions.
The guy I bought my car off advised this and was possibly giving me a dash and passenger airbag for free, so I'm after a decent quote and I now know what prices I'm looking at or should be paying.
If you have any of the above please feel free to send through a quotation / availability.
I do apologise for the confusion, Vic Roads were giving me the run around. So I wasn't sure whether to sell it or fix it.
Engine Parts:
Engine Fan Clutch, think it's the power steering component that bolts onto the side of the engine above the AC compressor (see photo)
Plus two rear wheel what looks like rear cradles , not sure the name of the part....(see photos) Pickles bent both with their forklifts.
cheers
If anyone is interested in buying the entire wreck AS IS I'm considering offers between $3-4,000. Nothing below as I know it's worth that in part value alone MIN.
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
    • Awesome! I was thinking S14 since they are longer. I'll give those a shot. Thanks for the input!
