I bought my 2535 cheap second hand on the basis of rebuilding it
The cartridge was dry, and after oiling it and letting it sit for a while with oil in the cartridge I took it to a turbo shop and they said it all felt fine
Been on for 18 months at 255kw and still going great
Anywhere that sells garret turbos should be able to rebuild it if required
https://www.sau.com.au/forums/topic/465713-hks-2530-found/#findComment-7756352
Except that they don't rebuild Garrett ball bearing cartridges.
There's info on turbobygarrett.com about a service program, but it's relevant only to the US market.
If the unit referred to by OP has excessive end play, the solution is to replace the entire cartridge.
https://www.sau.com.au/forums/topic/465713-hks-2530-found/#findComment-7756402
If you really want a fresh HKS GT2530 make sure the compressor wheel isn't damaged and preferably the compressor housing too .
If the one you're considering is for an RB20 or 25 it will have an integral wastegate T3 flanged turbine housing so it can make any GT28BB based turbo bolt to your factory exhaust manifold . Having said that there are limits to what sort of power you can get from even the best GT28xxR turbo particularly on an RB25DET .
If you expect an easy 260+ RWKW on petrol you probably really need a GT30 based turbo in a Garrett . GT3076R or GTX3071R would get you there easily with the supporting mods . GT2530s and similar are better suited to mild 2L 4s .
A .
  • Like 1
https://www.sau.com.au/forums/topic/465713-hks-2530-found/#findComment-7756736
A .
Thanks for everyone's help.
How does the GTX 3071R perform on a rb 20 and rb 25?
I have found only alittle info about them for those engines.
Edited by yoshiii335
https://www.sau.com.au/forums/topic/465713-hks-2530-found/#findComment-7756914
ball bearing GT2530 for an RB26, receipt says $980. was a couple of years ago now.
no details on receipt, but i believe it was a full reco with a new CHRA., cleaned housings and wheels etc. looked new when i got it back.
Edited by burn4005
https://www.sau.com.au/forums/topic/465713-hks-2530-found/#findComment-7758329
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
