Hi,
I have owned my r33 gtst for a couple of years now and ever since i got it the first thing i noticed was that when lock or unlocking the car only the drivers side indicator flashes. I was just wondering it anyone knew how to connect it to the hazards ( the alarm is an autowatch 446rli, there are 2 wires that create a 12 volt circuit to trigger the indicators). My main problem is not being able to grasp how the hazards activate.
Thanks in advanced for any help,
Joe
Edited by joseph0205
https://www.sau.com.au/forums/topic/465731-hazard-wiring-help/
Hey Joe,
You don't need to worry about how the hazards work, there is a separate wire for left and right indicators. It could be that the installer picked the feed wire from the flasher unit accidentally when he was testing. you just need to find where the connections are made and test. I'm not familiar with that alarm I only use Compustar and Viper, you may find a fuse blown from the alarm if it has two flasher circuits.
I normally trigger parklights unless the customer insists on indicators. Why would you not want to see those taillights flash!
well after much trial and error i still could not find out how the hazards worked. the only thing i am certain on now is that the wiring diagram i found for the alarm online is not even close to what is actually in my car (one of the previous owners did some really sketchy/weird electrical stuff throughout the car so im not surprised) Anyway i had come to the same conclusion as you, just using the parker lights instead.
Thanks for your help
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
