Did a search and came up EMPTY in this category which surprised me actually.
I have the Hypertune V2 manifold which has 12 bosses for fuel injectors and I'm thinking of using the other 6 (currently not drilled through) injector ports for water injection nozzles. I have seen where water/methanol injection consistently beats 116 octane fuel when used on top of 93 octane and I'm thinking this may be perfect for my streetcar. Does anyone here have any experience with this setup?
I am at the limit of 93 octane at about 20 psi boost on my 850cc injectors currently and have a pretty good fuel pump for it (AEM 380 LPH pump) so I'd like to keep from changing over to an E85 system for now (which would require another fuel pump, bigger injectors (1300cc), lowered fuel mileage, etc). The Haltech has extra PWM ouptus and I have a couple of digital relays here, so I'm thinking of installing a water/methanol system which will be controlled VIA Haltech.
I'm not sure what it does to the wideband reading, and I'd like to see if anyone has a "go-by" of sorts for setup (nozzle sizes, AFR targets, etc).
EDIT- I think I have calculated for 25 psi boost and 50/50 mix of water/methanol I would need about 800-1,000 mL/min of total injection rate. I'd likely start with 30% duty cycle and ramp this up with my power levels from 15 psi up (probably some ratio of fuel injector rate) up to 25 psi. So I'm planning on using (6x) 1.9 GPH nozzles and building a kit. I'll likely get the snow box to ensure flow during running as well (assuming this can be read by the Haltech).
https://www.sau.com.au/forums/topic/465743-methanol-water-injection/
I have the SPIII kit on my Gts25t but its a single point injection..........so I'm not even close to what you are doing.  And there is plenty on here about WMI, but in all the discussions Mafia or I and others have started, I can't remember anyone on SAU talking about 6 injection points or the setup you are looking at.
Search wmi or meth perhaps.
Pretty sure the thread n it was discussed as recently as last month so maybe just scroll down a few pages of topics even.
Would there be any issues doing it multi port, or benefits over single port?
This topic has actually had fairly extensive coverage on these very forums and there are a few threads that are actually quite recent.
You will NOT want to inject at the runners.  You want the water to go in as early as you can to give it some time to evaporate.  So into plenum or intercooler pipe is generally considered to be better.
Do as instructed above.  Search some more.  Don't use the forum's own search function - they are usually as weak as piss.  Use google and point google to just sau.com.au.
You still need more fuel.. so if you're at your so called limits then you'll need to upgrade your fuel system.
As you inject water/meth your mixtures will lean out, thus requiring you to ram in more fuel. Basic rule, tune for under 11:1 AFR for Gasoline, and inject water/meth to you bring your mixtures back to high 11s. Then start advancing timing... in your case you don't need to advance timing as you're already running so much for Gasoline I'm suspecting you're nosing over MBT for that rpm vs. load.
Benefits of multiport are the same as same for nitrous. Ensuring the same amount of protection goes to all cylinders. I would also add a 7th larger nozzle post-intercooler to reduce overall temp as well
Expand
Actually I'm reading the opposite of this from the manufacturers.
I'm running 6x 850cc Bosch EV14 injectors. They run very well. Seeing about 85% duty at 8k rpms and 18 psi boost. Also I'm at 19.9 deg of timing and no knock up there. I'm at about 24 deg timing at 7k rpms and it slowly dives down from there to the almost 20 deg.
1) a single injector in the post-intercooler stream will reduce intake temperatures which can help REDUCE power LOSS from heatsoak, but only makes more power IF: the AFR is adjusted on engine, the boost is raised, or the timing is bumped. If none of these are changed the engine will be likely more reliable, yet make less power.
2) They are saying that meth/water injection makes the mixture richer and reduces power initially if no other changes are made. Makes sense because methanol is a fuel after all and water is reducing the combustion temps in the cylinder which effectively should be robbing some amount of heat energy that normally turns into POWER. That being said, I think the additional ACTUAL octane of the methanol is marginal and is not what is making then engine safer to run higher boost and more advanced ignition timing...
Using the SNOW performance table here where I'm at currently (18 psi boost about 600 HP) they suggest a 624 cc/min (or mL/min same units) of injection rate. This means that really I could use an extra fuel injector (IF they atomized as well as water injection nozzles - which they don't) to inject the water/meth. Given a 50/50 mix the additional fuel is still around 310cc/min of extra raw methanol. Granted, methanol is supposed to run SIGNIFICANTLY RICHER than Gasoline so this amount of actual added octane due to the additional methanol is negligible IMO.
The benefit of a single fogger nozzle is that it cools the intake charge and having this upstream of my IAT sensor (which is smack in the middle of my manifold) would allow me to compensate for the decreased IATs.
The benefit of the multiple nozzles would be the ensure that I am getting the same amount of actual fluid injected to each cylinder as opposed to relying on the single fogger to distribute to all cylinders equally. I would say that this is the real purpose of the methanol as it would evaporate significantly quicker into the airstream and keep the vapor more evenly distributed in the air stream through the runners.
My goals would be to:
1) Leave the low end power level where it is at about 16 psi or so. Perhaps only inject on top end or at boost onset to keep the max torque from causing detonation. Stretch my boost out to 20 psi and see what it can do with WMI and more timing. Since the injectors could be leaned out (and I'm currently at 85% at 8k rpms at 18 psi) I think the meth/water will allow me to stretch these 850cc's out a bit more and the timing advance is simply easy free'd up horsepower at this point. This will max out my 850cc injectors I'm sure. Then once I get comfortable with this...
2) Change fuel injectors to 1,000cc see if I could support 24-25 psi reliably on the water injection and 93 pumpgas. I doubt I would want more than this amount of horsepower at that point because I would be worried the trans would totally grenade.
this is where I face palm myself :(
water/meth will richen up mixtures, as you're injecting a combustible.. I have no idea why I said it would lean out mixtures.. probably all the ethanol use has fogged my mind haha
  • Like 1
With the SPIII kit you can set the unit to idc and psi.  Plus you can start at say 14psi and have it all in by 18psi, and at the same time 60% idc and all in by 75% say.
I wouldn't leave it just for the top end, I would start my ramp up earlier and have the benefits already happening but ramping to max as you and where you need it most.  So I wouldn't just be thinking top end.
Its been a while [cos it just works], but I think mine is set to 8 and 14 psi and 40 and 75 idc.
  • Like 1
  I can build the whole table in the Haltech as well and just have it run the injector solenoid on PWM. I'd like to see how to wire in their little fail-safe flowmeter though as I'm out of 5v inputs. I may just run one of their kits with a couple of nozzles to get to 20 psi and try the individuals later when I want to run more with more fuel.
Expand
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
