GKTech Braided Brake Line fouling issue?
Hey guys,
I've had a set of the GKTech braided brake lines installed on my r33 gtst for a while now, but my wof inspector has just picked up that they are fouling on the stud from the sway bar link and that it's a wof failure, now these hose are a different design to factory brake lines as it is one solid hose from chassis to brake caliper rather than having the box bolted to the caliper.
Have any of you had this issue and if you have how did you fix it? I was thinking of using some P clamps but I cant see anywhere suitable to clamp it to without stretching and straining the hose :/
Any help would be highly appreciated!
Cheers
shit man. There's a stud already right there from where the factory brake line bolts on. Get a p-clamp, make a bracket up, you got to get that shit out of the way of the swaybar for sure, not surprised he failed it.
fair enough, yes that is a different kettle o fish...but make up a bracket, stick a p-clamp on it ( I use a pretty loose fit, just enough to guide it not hold tight on it) and loop it around like the factory bracket does.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
