Hey there I've had this problem for quiet some time now and am seeking desperate rb guru knowledge,so my series 2 rb25det auto r33 is reading error code 21 thru the diagnostic port , iknow its ignition signal code ,I've replaced coils ,sparkys (twice),CAS,AFM,and still the car didn't start? Now funny thing igot ahold of a rb25de auto ecu and loom wired it up too see if it will start and it DID on 25de brains(ecu)? yet no go on my 25det auto ecu ? Does this mean the ecu needs resetting or perhaps fried ? This problem just ocured out of the random after turning car off 1 day ?!?!? All help apreciated
Sounds like it. Next step is to try to borrow a S2 25DET ecu (preferably auto but any would do for start up) and if that works you can start looking for a proper replacement. You could try taking the lid off yours to look for any obvious damage that you might be able to repair
I'm in wellington and I'm tryna find a s2 25det auto ecu proving to be a mision and have removed cover couldn't see any obvious damage my guese is replace ecu due to car starting on a auto 25de brain
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
