S1 RB25 in a R32
Low(er) idle with the A/C on and no increase in rpm when turning the steering wheel.  Opposite of normal, right?
I had the engine cleaned out with a popular product here in Japan called Wakos RECS (Link) the other day and I didn't notice any change in idle conditions on the drive home.  I then promptly took out and cleaned the IACV to hopefully rectify a different idle problem. I removed and cleaned the cold start air regulator as well. Only, after putting it all back together did I notice the aforementioned A/C and power steering idle problem.  I cleaned the MAF today and reset the ECU and that didn't help.  No ECU codes are shown.  Stock ECU by the way.
It idles around 1000 and with A/C it dips down to maybe 550 and then up to 650ish.  Fiddling with the screw on the IACV doesn't seem to change the idle rpm very much.
Any ideas would be greatly appreciated!
Thanks, Rory
https://www.sau.com.au/forums/topic/465793-iacv-not-perfoming-but-performing/
Definitely plugged it back in properly. I just went out to readjust the idle properly (didn't disconnect the iacv before while doing it), but that didn't fix the problem.
Idles at 900, A/C goes to 600 and then not so slowly up to almost 800.  It IS working, just not properly.
  • 1 month later...
Its been a while with no changes being made on my part.  Anyone have any new ideas?  When I removed the iacv the gasket bent/ripped a little bit.  Think a small leak there would cause this problem? I ordered a new one, but still seems like it wouldn't cause this.
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
