Tein RS Circuit Master ( rebuilt by racepace)
Set of race pace tein rs circuit master coil overs
Possibly the best upgrade I have done to my car( on the exact same car shaved 2 seconds off on a 60 second lap out of the box)
Approximately 2000km old
Tarmac rally spec so perfect on the road and bumpy tracks
Best money you will ever spend
Suit r33 and r34
$2700
tein.jpg.0357897766150e22d76ac3d612f1ba9
 R33 gtr Ap endurance setup
Front
365/355 6 piston Ap racing endurance kit
36 mm full floating rotors
Endurance calipers 35mm pad each side
Race brakes custom lines
Spare set of rotors and hats
4 sets of front pads
Rear
330 4 piston endurance calipers
Full floating
Custom lines
Spare rotors
3 sets of pads
$5000 with brembos exchange
can also include a full Ap racing balance bar setup and hydro handbrake setup to match for extra dollars
This is a serious setup that takes a lap or two to warm up then it rips you face off till you get bored or run out of types and fuel
b4.jpg.ee8bae9a861e353839b07c3916cd1c44.b1.jpg.6c55d9bf0b0142768f1a42e053b697e7.b3.jpg.b2c248e00ac9a676f5671ebdb36fecf4.b2.jpg.88dd91ee718d0dba23ac201a3ffc7523.b5.jpg.dbe0bbaa7cb35f3211f4d8126e5d11a4.b6.jpg.718bfad316a4029fbc3030e1f4ba2f3b.
4
Os giken 5 speed in s3 gtr casing
Billet input
Os tripple plate
Push pull converter
Was assembled by award diff
6k plus a stock box my way
Box and clutch have done 1-2 k
In car and can be tested
No pics as its a box and In the car
box.jpg.ca050b82d19a32dd55c976bb2cacce67
all shit located in theblue mountains sydney
if you want something ive me a call come over inspect and buy
pete
0448468884
https://www.sau.com.au/forums/topic/465796-race-r33-gtr-parts/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
