Now that just sucks - doubly so. You can't fight them on fuel quality. I once went through 20L in 25km. Car was billowing black smoke the whole time. It was clearly poor fuel in the stock auto GTS25t and it compensated by going mega rich and using as much as it needed to protect the engine.
The bolts are definitely a no-no to re-use.
Rebuilding my engine last time I was torqueing them up and one kept turning a bit too far, then bang. It was nowhere near first torque and had failed. I measured the rest and found some were a fair bit longer than the others so got new ones from Nissan.
So is the builder springing for the new work or was it your decision to use the old bolts?
Initially he was going to get me to spring for it - act of god he called it.
Thing was - it was his decision to re-use. Could have turned out nasty, but he has come good and is paying for the new block, all labour and all machining. As it turns out there is a fair bit salvagable from the blow up. I am paying for 3 new pistons, bearing and gaskets and of course bolts. Not too bad considering - just pissed off that I have to go through the whole bedding process again. Haven't been on the track now for nearly 4 months. <_<
  • 1 month later...
i got a qestion need answering iv got a mate with a R31 that f*king boots his turbo is at 15 PSI n he wants to turn it up 2 17 u rekon thats a smart move or not?
Need more info on the engine mate, what motor? what turbo? kms? condition? blow smoke? rattles? leaks?
how longs a piece of string?
Another one to add to the pile.
R33 GTST 95 mod.
Unichip
Intercooler
GCG hi-flow
Finer filter panel
Full exhaust & split dump
Bosch pump & sard regulator
215rwkw
very happy !
Unfortunately this is where it all goes wrong.Developed a small hiccup at 2,000rpm then 2,500 and took it to biggest most expensive u-beaut tuner in sydney.On the dyno and he says crank angle sensor gone.Removes unichip and cas is fine.So must be unichip.
Couple of days later same hiccup.Then it is fine.Then really bad.Back to dyno.He says must be cas.So I had one ready and away we go.Car drives great.Couple of days and no power below boost but goes good on boost.At this time I decide to install pfc and hi-flo injectors.Hope pfc will fix problem.225rwkw and running great.Before I get home notice lack of power below boost and slight hiccup.Take it to Advan who kindly run it up on the dyno then street test and we confirm timingis rooted.Back to original tuner and dynoed.Tickles pfc and says it`s fine.Go to start it and won`t start.
Timing belt has let go when I turned it over to get off the dyno.All the trouble I had been having was in fact the belt which had lost 30% of it`s teeth.Belt had done 30,000km`s but looked like 200,000.Cheap belt from f#@%$wits are us.Cheap-skate so called engineer who`s favourite colour is green possibly damaged it when installing.
  • 4 weeks later...
Engine/Car: r33 series1 rb25det
Type of failure: Number 5 piston letting go and destroying block and crank and deep grooves in head. Oil pump failure. Dads a mechanic he told me it was probably a sticky valve making noise, should have checked oil pressure. Noise was piston hitting head!
Factors influencing the failure: Warm weather, Oil pump, Motor had a couple of dodgy coil packs leaning out and detonating. Poor maintanece really. Learnt that mistake
State of tune of the engine: FMIC, cat back 3.14, hks pod, n1 water pump,
Suspension and tyres: kyb struts, jap springs of some sort, pinaples, control arm bushings. 235 45 17 pottenza reo 40
Oil used and service interval: Good sythetic oil cant remember, Serviced approx 3000km before this
General comments: Very inconvenient time for this to happen. Has made me slightly wary of rb25det now. Had a sylvia before this gave it hell still going strong! I want a head up display oil pres now!
we could barely make out mitsubishi stamp.The rubber had completely fallen apart.
Have a mitsubishi belt on mine at the moment, just gone 20,000kms old and it looks like rat shit... must be a common problem.
Got a brand new HKS one sitting in is box waiting to go on.
Engine/Car: r33 rb25det
Type of failure: broken ring on #6 piston.
Factors influencing the failure: had the car tuned on 12psi (safc2), while at the drags the dodgy bleed valve spiked to 18psi and actually held it there during my burnout. it was smoking all the way down the line.
State of tune of the engine: 3" turbo back, fmic, pod, safc
Suspension and tyres: stock
Oil used and service interval: nulon synthetic.
General comments: DO NOT USE A BLEED VALVE. THEY SUCK.
  • 5 weeks later...
Me again
Engine/Car: R33 GTR
Type of failure: Spun bearings due to suspected oil surge. <_<
Factors influencing the failure: 2nd lap of a track day. Fairly warm day.
State of tune of the engine: approx 700bhp (fly)
Suspension and tyres: Ohlins / Eibach running Dunlop D02g's
Oil used and service interval: Motul Race Oil - changed after every track session.
General comments: After last rebuild used Tomei sump baffle kit, cam cover baffles, gallery restrictor and Accusump. Obviously not enough. Currently having the sump modified by Performance Metalcraft. Hopefully this should do the trick :P
  • 3 weeks later...
R32 GTS4 - RB20det
Type of Failure: Spun bearing - oil surge
Factors influencing failure: A litre down on oil, round a corner 5k revs, third gear full noise, bang
State and tune of engine: 3" cat back, pod filter, ran well for 15yr old
Suspension and tyres: stock suspension, new 16" rubber
Oil used and service interval: Castrol magnetic (daily driver) only serviced it once in the month I owned it b4 it blew...
General Comments: The one time I didnt check the oil b4 going for a drive, and I find out now what they mean by a cheap car isnt cheap if you cant afford to fix it when it goes bang... The replacement engine went in this weekend - what a mission! I have never done a swap b4, but I had a friend who has, it took us 4 days. I have bought some nice synthetic oil now, and looking for a 5" oil pressure guage :)
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
