Zac, BBQ and Rianto thanks for the posts. The R33 GTS25t fuel pump is a bit of a weak link, as are 180sx Silvia pumps from experience.
Geoff, after driving my car for a while with the new fuel pump, I noticed that the clicking/rattling noise in the engine bay seem to disappear. I think since the car is no longer running lean, the new pump has cured the pinging problem and the result is a happy engine with smoother sound when revved. I finally got a chance to fang it down a private track yesterday and boy does it pull strongly in all gears.
Excellent news Rianto. I just hope no permanent damage was done. Have you had a workshop look into the cylinders with a scope to inspect for possible bore damage? they just go in through the plug hole with the piston at BDC.
Sorry to hi jack the thread but in reply to bobjones, Chevy454 con rod bolts fit into RB20 rods but the rods require the smallest of machining less than 15 thou, but the bolts are the right length and have the same shape head.......
Thanks for that.
I spoke to Simon on the weekend, and I can say is I feel for you. And I would be getting stuck into that other guy...what a tool.
I like the cooler where did you get that done????
I was in there on Saturday and you box is now out, are you getting this serviced while your at it???
I was there pulling the timing belt off again as an idler was making a funny noise...nice little project for a Saturday morning then put it back together so I can go out...
the car now runs like an absolute dream which is testiment to Simon, Rob and Wayne (who works elsewhere) You will be happy with the result. Just took a long way to get there!!!
So every step along the way my workshop has been honest, the scary thing is that some people are not.  Currently, in this workshop there is a 180, with a $15K engine, when we pulled it down, no forgies as told, and the reason for the engine failure...standard bottom end bearings in the WRONG way...
Hey thats my car! Lol! I knew it didn't have forgies in it as I only wanted a std rebuild. I was supposed to watch the rebuild but didn't, I wanted to see how an engine was rebuilt so badly (I have never seen it before) I guess I went to the right place!
Other mistakes he did miss-aligned camshafts (both) 2-3 teeth out (The fella didn't know why it didn't run properly so another shop diagnosed this as ECU so I had microtech fitted which did not solve the problem obviously), sealant in the oil pump which caused low oil pressure and destroyed 3 std turbo's and of course the lucky special upside down bearings!
The conversion cost me $16k at the time but $6.5k of this was fixing the engine rebuilders stuff-ups (but includes microtech (missdiagnosis unfortunately but it shouldn't of had to been diagnosed in the first place), 3std turbo's, my new turbo(T4-T3 hybrid), new clutch (as the last one I thought was shagged as it slipped and felt weird-pedal went soft/hard at different points) when the new clutch was being fitted it is how my mate changing the clutch found the 2-3mm endfloat in the crank, new oil pump + fitting, other bits and pieces. Now factoring in the new rebuild it will of pushed my simple RB conversion over $20k, if it cost me $10k with std rebuilt RB20 I woulda been a lot happier.
 The funny thing is the guy who stuffed my engine up has a chip on his shoulder at ME! Lol! funny little fella! He works at his old mans shop and at first he (the young fella) said they would pay for everything, then his old man said he offered no warranty as I was involved in the conversion (I fitted fuel pump organised wiring loom etc but NOT the engine build)! So they are only paying for new crank and bearings only and removal and refitting of the engine only. I have had to pay for everything else (head rebuild/re-co etc) lucky it was only the bottom end that was stuffed the head was ok no foriegn matter. Funny thing his business card says "guarantee's on all work" Hmm may have fun with that.
Oh yea sorry for the long post
Geezuz that is alot...
Oh and it must be either a 1, 2 Warranty or a Concrete Warranty...Once you have it 2 bad, or it leave the Concrete there is your warranty...
Once you get your car back I think you need to pass on this guys details...
Engine/Car: 33 GTR VSPEC/RB26DETT
Type of failure: No Exhaust wheels on turbos, possible further engine damage.
Factors influencing the failure: Car blowing lots of smoke 1 day after purchase, took it back to the dealer to be fixed full well knowing the turbos were ****ed, a week later i pick it up with nothing more then cleaned intake pipes and fresh oil. 2 days later, no boost.
State of tune of the engine: HKS cat back, HKS cooler piping and pods, rest it stock
Suspension and tyres: Stock
Oil used and service interval: Just what came in the car, first time i didnt change it as soon as i got home.
General comments: Not happy, this has lead to lots of complications with the dealer not wanting to repair the car, its waiting for my mechanic to come back from holidays to be pulled down and inspected but i havent driven the car for more then 8 days since purchased on the 7th of July :)
R32 gts-t RB20det
1st failure:
TYPE: ALL ring lands cracked several times
REASON: driving car without tune and 1 bar boost
MODS: HKS 3037s, FMIC, 3" exhaust, 044
SUSPENSION: Tein HA
Comments: do not drive car with with broken ring land, and catch can, hard. painted my car with oil several times. drove in this state for over 18 Months
2nd failure:
Engine 500kms old
happened last night.
TYPE: no 6 conrod nut come off and got mangled, possible spun bearing, bend conrod, stuffed crank
REASON: put conrod cap on backwards when rebuilt engine. Had car on dyno getting tuned up to 5000rpm last week, went for a drive last night, 1st through to 4th gear up to 6000rpm, did this once then, *rattle *rattle.
MODS: stock turbo 8psi, GTR cams, GTR injectors, 3" exhaust, FMIC, 044
SUSP. TIRES: Tein HA's, Toyo Proxes T1-S
comments: i don't know how i put it on wrong i checked it about 10 times. maybe i shouldn't have done that bit at night, other than that goes good, will have better investigation of damage tommorow when i pull it all apart. i really don't won't to have to replace my conrod as it doesn't look bent but i think it may have suffered a bit of fatigue what do you guys reckon.
Engine/Car:R33 GTS-t S2
Type of failure:broken ring or piston in cyl #3
Factors influencing the failure: too lean holding 6k in 5th gear
State of tune of the engine:road tune (hard to do with a screamer)
Suspension and tyres: std shocks on apexi springs - jap tyres
Oil used and service interval:variety but always 5w40 every 5k
General comments:havent stripped it down yet to find the problem but oil on a spark plug isnt good
Had the same problem...turned out to be the rings...hopefully it will be the same for you...
Engine/Car: RB20DET HCR32 GTS-T
Type of failure:
Melted piston and busted rings.
Bought the car with a sickfuel pump.
Upgraded to an RB25 Turbo still didn't know about the sick fuel pump.
I finnally had the car dynoed and then after seeing 16:1 a/f ratio bought a new fuel pump.
Stock computer.
D2 coilovers. Set of R33 rims.
Penright engine oil.
General comments:
After I fixed the fuel pump I decided things were ok and got a FMIC.
After that and 16psi I manged to fill a catch can up in one night.
Anyway I knew the time was near for it to tottaly shit itself.
Motor lasted 12months with the cooler and 16psi with low compression on pot one.
The motor decided to die finnally at the drags 4 months ago.
Cooked them pistons good. :flamed:
Had my car a few months then the rear turbo ceramic wheel snaped due to exessive boost Metal hard pipe had worked loose. This scored the cylinders causing lots of blue smoke on the way home.Striped the motor and found scratched oil pump . Marks in valves and seats,scratches down the sides of cambuckets,Cams and bearings scratched. Crank scratched.Hego broken.The block needed metal stiching as it was cracked between the water way and head bolt hole(nothing to do with the turbo problem). Also showing signs of a porus block above the turbo oil pipe fitting.Rebuilt using N1 oil pump First oversize ACL shells rebuilt turbos with steel internals JE Pistons. 500 Miles after build on of the turbos failed. Changed to 2nd hand HKS 2540 50 miles later knocked a end out. Striped the motor crank centre bearing broken up ends worn oil pump marked. Found the crank to have bad wear at the contact area with thrust washer. Sourcing another part at this time.
Nissan Skyline GTS-t M-Spec
Engine temp went sky high, lost power and started rattling
Dented oil sump prevented oil pick-up... therefore no oil was feeding thru!
Unichp, 3" exhuast, 18psi, steel wheel turbo,
Bilstien coilvers, Bridgestone RE540s
Oil changed every 200km/every second race meet
Pulled the engine out, put another one in, retuned it and back on the track!
Spun bottom end bearing in my RB20 as well. The night before it happened was under the car fixing jammed wastegate only to see that the sump had a dirty big dent in it.
Car had an intermittent miss at high rpm due to old shoddy plugs, IMO the combination of these two factors cost me the engine.
yeah, this was something we simply over looked.... expsensive mistake though.
mine has a drama with the throlle position sensor too, appears to stutter when you try and hold revs at different throttle positions. realy pain in the arse.
update on my shitter, turbos are off, strangley only the front turbo spat the exhaust wheel generally its the rear, nengun sent my new ones today so hopefully i wont be making a new post in hear netime soon.
Rear turbo:
Front Turbo:
Engine/Car: r32 gts-t rb20det
Type of failure: rings / turbo
Factors influencing the failure: unknown, atm bov? injectors cloged? oil?
State of tune of the engine: cat back/ pod filter / stock boost
Oil used and service interval: just picked car up (they had just changed oil)
General comments: The car went like a dream untill they changed the oil. The car start pinged going up a hill (backed off) got to top bov went off car stalled. restarted car then noting but smoke. atm bov was spraying oil lots of it. pressure from cylinders was spitting dip stick out and spraying oil.
went back to dealer :rolleyes: they replaced engine turbo. Now the oil pressure is getting low when the car has been running for 40min+. I am also starting to get pinging when the engine is hot under full boost. :hellpisd:
what do I do as QLD is starting to warm up which I Know will cause more problems.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
