I'm 6ft and have always weighed around 60-65kg, this made me resemble a clean cut heroin addict.
I signed up to the gym as support for my partner as she wanted to lose some weight. Little did i know I would be hooked after noticing some strength gains.
Starting program as of 2 months ago:
Bench: 6x10 30kg
Lateral raises: 6x10 5kg
Upright rows: 6x10 45kg
T bar: 6x10 30kg
Program as of 15/7/16:
Bench: 4x8 60kg 3x8 55kg
Lateral raises: 2x8 10kg - 4x4 10kg - 4x4 8kg
Upright rows: 2x8 65kg - 4x8 60kg
T bar: 2x8 45kg - 4x8 40kg
I've been slack with leg days as i am always on my feet at work. This will change next week. Say hello to the tin man!
I just had a new program made today with roughly 8 new exercises, so i will get a base weight on each exercise and update as i go.
Why so many exercises? If you're trying to build muscle why not stick with the compounds rather than isolation?
I'll let you know what they are this afternoon leash and you can let me know what you think. I had a few goals in mind which would have contributed to the program. I.e. Bigger chest and to pull my shoulders back.
Right now I'm waiting to be seen by my physio as I think I've pinched my ulnar or it's being squished. Booked in for a massage Wednesday too.
Good job getting straight on the physio.. unfortunately it seems part and parcel of lifting! I have acupuncture regularly these days. Massage can be beneficial as long as it's done by someone trained in remedial or sports massage.
Edited by L33SH
Great to see you attacking the iron Trex !
In terms of putting on mass , it's not hard once you have the basics . Just remember genetics will govern how this all works for you but, you can be a totally different looking 'you' in as little as a few months .
Compound movements are key as the very savy L33SH has pointed out ,along with eating well and getting rest This will see you tipping the scales the right way with strength as a bonus. To make life easy you can try out "strong lifts" . It's got an app thats easy to follow and takes some guess work out of begining.  Strong lifts is just a rehash  of the good old 5/5/5 workout, it does the job. I'd also couple this with getting to work on fixing your shoulder girdle and scapular mobility and strength . Some movements with bands like YWTL's you can fit between sets doing things like bench that focus on internal rotation . Also stretch out your chest, daly. Nothing that takes alot of time, we are talking 10-20 seconds of streching a few times a day for the chest. Youtube has stacks of good channels with examples of stretches to improve shoulder mobility too.
It's possible the ulnar nerve thing can be related to shoulder issues, get a tennis ball and lean against it on a wall (roll around the rear of your shoulder and upper middle back for tender spots.If you find one hold on it on the most painful spot for a good 20 seconds with pressure , repeat each day till it improves.
The current workout could be impacting that also, as it's got an over emphasis on interna shoulderl rotation movements  . Lose the upright rows completely, they aren't great for development and put the shoulder in a less than ideal position. Ther are better movements not least of which is the overhead press (learn to do it right). Again strong lifts isn't bad.
hope those thoughts help a little .  Bottom line is do the work and you will see the results .
Edited by rev210
  • Like 1
If I can just add to your post Rev; internal rotation is an absolute must! I'm seeing a specialist due to shoulder bursitis and I've been doing internal/external rotation exercises and incorporating band pulls into my workouts too. The specialist has really honed in about having a strong posterior chain and core, (which I'm working on atm to improve pain associated with lower back disc protrusion.) I've started doing yoga and Pilates again... The amount of strong males in the classes is impressive. There's a couple of football players in the yoga class who are very agile and flexible. So if I could make a suggestion... Don't forget the posterior chain!
The bloke doing my massage is the same bloke who is doing my programs at the gym. Has all the certs etc :)
I will never go to one of those mall massages, none of them have been able to name muscle groups, bones etc. It's quite shocking.
My physio agreed it could be the ulnar is being pinched, could also be measles as he has had a few cases of ultra sensitive skin, forearm pain etc. I have 3 new stretches to add to my morning routine and I am going back on friday for a checkup.
By genetics you mean family traits? If so I should be massive lol. My elder brothers are pretty big and my twin looks like he lifts when he doesn't.
I will be giving this new program a go before i change it up, i didn't think much of the last program but have seen great progress in body size :) The bloke doing my programs has trained quite a few skinny's and have seen them around the gym, their transformation is something to be admired. What is the 5/5/5 workout though? Is that arnies one?
I don't exactly have a rest day, I work with australian hard wood and lift all day everyday. This has been very evident in that my body fat has decreased while my intake has increased to 4 meals and 3 mass gainers a day. I have to force more in and take it easy on satuday and sunday.
I stretch every morning for 10 minutes before work, most of my stretches are from my physio with certain problems i have had in the past and for the work i do.
Yep, not doing the upright rows anymore, i did read that a lot of people have had problems with it, i do enough of them at work anyway :P
ok so figuring out weights tonight. Will probably take another 2 sessions to get an exact weight down.
1:
Bench - 20mins - 3x8 60kg - 4x8 55kg
Incline bench - 20mins 6x8 40kg
DB bench - 20mins 6x8 15kg
Dips 20mins 5x5
2:
Pullups - 20mins
Seated rows - 20mins
Lying bent over row - 20mins
Curls - What ever
3:
Squats
DB sumo squat
Hamstring curl
Back extension
Situps
I believe i a doing a 5 day workout, will have to confirm on wednesday.
mon 1 - tue 2 - wed 1 - thur 2 - fri 3
I'm a big proponent of stretching and yoga type holds these days. I do them on weekend mornings when I get out of bed and sometimes after exercise (have heard it's not good to do stretches less than a couple hours before an intense workout). I read some info that suggested stretching will help with muscle growth by stretching the muscle fascia, allowing the muscle more room to grow along the joints rather than being shortened by constant contractions from exercise with no stretching.
Whether there's truth to that or not, there's no denying my mobility and flexibility have improved - much less injury prone now and old injuries have all but disappeared by increasing the range of motion with stretches. The best exercises it has helped with are plyometrics like box jumps. Now up to 125cm and counting :)
  • Like 2
I've explained a few times now the most efficient method for what you want to achieve
E.g. Why dumbbell press after bench press?
You'll have to excuse me, I don't understand. This is all new and some lingo escapes me even after googling.
I have a very small chest. Like almost non existent, and I also don't feel anything in my chest even though I get a 'pump' that's the only explanation I can see as to why doing more chest exercises.
Incline I feel it in my shoulders which is a plus.
And I want to pull my shoulders back, that's my understanding of seated rows.
Laying bent over rows do middle lower back.
Pull-ups will do traps and middle upper back?
And dips do shoulders triceps and if I lean over will do more chest if I like.
1- chest, tri, ant delt
2- back, biceps, pos delt
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
