My Bora is AWD but predominantly FWD until shit gets real.
Over the last few months, theres been noises coming from front drivers wheel when turning at low speed.
I don't think this is a CV joint!
I've heard a million CV joints go and this sounds and behaves a little differently. While a blown CV makes a bit of a 'click' noise, this sounds like a 'boing' noise. If you were to pull the sway bar away from the chassis and let it go, it would 'boing' (or bounce) against the chassis - thats what this sounds like. Also, this morning I had the car on lock and reversing and there was less noise (as opposed to more if a CV is gone).
I either can't hear it, or its not there are higher speeds (10/15kph+.)
It also doesn't seem to happen on all surfaces, its really bad in the polished concrete car park at work, but less so on the pavers at home but maybe this is simply due to a lack of traction.
Does this sound like anything in particular? What should I be looking at if I jack it up? Or maybe I use ramps so the suspension is compressed?
Thanks in advance.
C
11 minutes ago, hardsteppa said:
Well i have found a tiny amount of looseness in a swaybar link nut will make a hell of a racket so maybe is just it "slipping" when under load?
Yeah might be. I guess I need to get under and have a prod/poke at things. I was hoping my explanation would have an 'Ohhh THAT sound! Thats definitely a ... ' response from somebody.
Thanks @hardsteppa.
Check that your front shock top nut is tight and your top mounting bush isn't worn.  If you have any play in the shock spindle when you wriggle it then your up for new rubber/nolethene bushes.
  • Like 1
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
