Here is the scenario:
Mate driving his car down free-way... Car then dies (lights / engine) Lights come back on, but engine stalled... Goes to start engine again, but it is noisey.... So get it towed...
- Try to start now, struggles to turn over when cold like very, very slowly.. (Drains battery fast) Would it be big end bearing / or the likes.. HEEELLP!!!
Car is std with only a BLITZ FMIC / 3" exhaust / Pod filter... Std Boost etc...
:throwup: HEEELLLPPP!!!!!!
- Have put new battery in, as old one was dry, checked, throught it may have been regulator in Alternator had failed, causing over charge of battery, causing it to over charge and dry out, and cause alternator to get thrashed out and become noisey.. NOT that
https://www.sau.com.au/forums/topic/46586-broken-rb-25det-heeelllp/
Another thing i forgot to mention is that the Exhaust cam is out of sync by 3 teeth on the timing belt / alignment at top dead centre.. I think it is more than a starter hey.. Do you know how we can check the starter motor at all?? Just seems odd that even the engine is very hard to turn over, even by hand??
I have never heard / seen this before.. That is why i ask before commiting to pullin the engine out....
Pull the spark plugs out and see how easily it winds over. If it still seems sluggish then starter or binding of some sort.
Make sure the battery is fully charged as well. drop a little oil from the sump, just 100ml and look for silver/gold flecks of metal to determine the bearing wear.
And fix that cam timing......
The plugs are out, and it still struggles to turn over... Hard to even turn over with socket off the front of the crank....
I just dont want to comit my self to pulling it out and nothing is wrong.. He has alway said it has been laim as when driving and would get beaten easily by another std skyline...
How would you check the start motor?? Pull it out??? As the battery is now brand new, fully charged?????
Should whirl like a dervish now with the plugs out. Make sure the attachments aren't causing it. Pull the belts from the AC, power steering and alternator. In fact I am highly suspect of the AC if it is fitted. Would struggle to start and kept stalling. Was the AC compressor was siezed and the clutch material in the compressor was slipping letting it run.
What exactly was the noisy sound like? A tap tap tap or a grinding noise?
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
