I picked up my r33 a little while ago, its very stock (everything is factory besides atmo bov, pod filter, SAFC). It's running very rich, car distinctly smells of fuel. I've had a theory that it would be the atmo bov. I don't like the atmo bov so im going to go back to standard recirc valve, but I need opinions on the SAFC. Is it worth keeping and tuning to try run a bit leaner, or should i just remove it from the ECU?
https://www.sau.com.au/forums/topic/465861-r33-rb25det-running-rich/
SAFC is shit.. you bend your AFM car runs leaner (good) but you end up running more timing at the same boost (bad).
I've played with one a decade or so ago, but to keep things safe I retarded the cas by 3 degrees.
  • Like 1
''played with one'', is not the same as taking the time to use them to their best effect. ie, who says you only use them for leaning out, mine adds fuel/pulls timing in top end due to boost increase.
@WMDC35I don't know anything about SAFC's/tuning etc, this is my first car (obviously my first import) just trying to learn as I go, so what is an AFM spacer?
Also i'm not really in a financial position to buy a whole new standalone ECU/Tune, so i'm tossing up whether to get the SAFC tuned or to remove it entirely, opinions?
Im searching around for a standard bov, ill let you guys know the results once that goes in!
Thanks for all the replies and advice already given, appreciate it!
they don't correct timing, show me how they correct timing.. enlighten me
Where are you located? I have a spare stock BOV you can have for cheap cheap
hey simmer down now sex kitten....they do this in the same way that everyone likes to point out, when you lean them out  (by moving the signal lower down the load band) it can, but may not always, add in extra/excessive timing....and moving the signal up the load band in the same rpm scale to add more fuel by way of increased airflow signal can, but may not always, pull some timing out.
I would not consider them a suitable choice to 'tune' with but would consider them suitable to adjust a tune with.,,,if you get what I mean -  basically don't ask them to do too much.
I have found the main issue to be that with only hi and lo throttle adjustments the correction range is too broad, would be much better if there was a midrange throttle adjustment. But they aren't *shit*, just limited in their use. If OP is not in a position to buy a standalone as they say and already has an safc, then make the most of it.
I ran an SAFC with my high flowed RB25 BUT I also had an SITC (they are getting hard to find) to modify timing. Relatively crude but do-able. Obviously a proper ecu is better but I had these when I still had an auto box.
Hey guys I have an update
As of Friday, the car now has extreme trouble firing on warm start, cold start is perfectly fine, but the car just won't catch on warm start.
Beginning to wonder if my coolant temp sensor for the ECU is buggered, anybody know where i can buy one?
genuine ones from kudos Motorsport for around $40 from memory.
Delete the SAFC, it's probably bending too much of your AFM signal and giving you grief.
Too bad you're not in Sydney, would have recommended a Nistune.. if you still want the board, I'm able to get them below RRP for all SAU members.
Can you get me one ?
Do you install the board as i have a z32 ecu already to go
Pm me if you like with the details and price
Thanks man
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
