Alright so about 2 days ago ive changed the coolant and actually put coolant into the car as before it just had water running through it, my car has been overheating roughly about 15-20 mins after driving depending on how i drive it if i thrash it it starts climbing but if i drive normally it keeps cool then slowly starts to heat up. Ive started turning the heater on full blast as that sorta fixes the overheating problem while im driving but does this mean it could be the thermostat thats screwed or could it be something more like a blown gasket or something? ive noticed that some hoses on top of the engine have some crystalised brown stuff leaking from them, could thise be the old coolant thats clogged up and crustified there blocking the flow of oolant into the engine?
also another question are any other struts from other nissan skylines interchangeable with the struts i have now?
Please any help is appreciated and needed!!!
https://www.sau.com.au/forums/topic/465870-problems-with-my-r34/
Have i bled it? like Burped it?-.......No i forgot too, hopefully that fixes it.
Fluid level is good as the reservoir tank and radiator are always full and only require little bits of coolant to be added after running and turning off but i might need to burp it.
The bottom hose is hot
and the top hose is firm when its up to temp.
Ive been reading and im thinking it could actually be a blown head gasket.
One day i overheated and my reservoir tank was boiling/bubbling/popping it was going nuts could that be head gasket?
If you haven't been using "anti-freeze" your system could  be full of rust and cr*p.
First try bleeding all the air out (search if you're not sure how).
Get a radiator shop (or your friendly mechanic) to put a pressure tester on the radiator to spot leaks or may tell you if there is a major leak from the head gasket. Have a look through the filler at your radiator core. May need cleaning or replacing.
Get a new radiator cap, sometimes they get old and the spring wont function thus not letting water into the engine at operating temp.
Also do a proper bleed, top up the reservoir past the full line. Top up the coolant, turn the heater on full and whilst the car is running loosen the coolant bleed screw near the front of the plenum until coolant comes out.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
