Adaptronic Ecu -
http://www.adaptronic.com.au/product/esel015/ Currently has the z32 map and harness plug, however the Z32 market isnt huge so I have spoken to Adaptronic who will change it to any nissan base map and plug for a small fee which I will cover depending on what sort of car you have. $1200 Lots of features as seen below. This is plug and play so no stuffing around with install costs.
Features:
  • Built in 4-bar MAP sensor to replace the factory airflow meter.
  • VE tuning to simplify injector upgrades and simplify staging
  • Easy to use software
  • Plugs into factory wiring
  • Compatible with many third party dashes and devices
  • Full closed loop operation
  • Flex fuel capable
  • Launch control, antilag, flat shift and boost by gear all standard
  • Semi sequential injection and wasted spark ignition
  • Spare 0-5V analogue input
  • On the GTR / R32, VVT output can be reassigned to a different function
  • One additional spare aux output
  • 3 spare digital inputs
  • Spare temperature input
  • Compatible with single and multi throttle body (for GTiR) tuning modes
SPECIAL FEATURES
  • This ECU also supports all the functions of the 440 ECU, however for advanced functions such as traction control, additional wiring and/or sensors will be necessary:
  • Flex fuel function – fill it up with gas/petrol or any ethanol concentration
  • Adaptive fuel control (self tuning) – reduces dyno time
  • Traction control function
  • Serial input for wideband O2 sensors (we recommend the MTXL)
  • Serial output for communication with dashes and dataloggers (we recommend the Race Technology units)
  • Headphone port for listening to the knock sensor while tuning
  • Basic closed loop ignition control
  • Closed loop fuel, idle, boost, 2 x variable valve timing control
  • Dual maps (both maps required for GTiR for combined TPS / MAP tuning)
  • 4 weeks later...
  • 4 months later...
FYI, there are instructions in the manual on how to change this from Z32 to gtst and gtr. Very easy. Basemaps also free with the software download (also free)
  • 3 weeks later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
