Adaptronic Ecu -
http://www.adaptronic.com.au/product/esel015/ Currently has the z32 map and harness plug, however the Z32 market isnt huge so I have spoken to Adaptronic who will change it to any nissan base map and plug for a small fee which I will cover depending on what sort of car you have. $1200 Lots of features as seen below. This is plug and play so no stuffing around with install costs.
Features:
  • Built in 4-bar MAP sensor to replace the factory airflow meter.
  • VE tuning to simplify injector upgrades and simplify staging
  • Easy to use software
  • Plugs into factory wiring
  • Compatible with many third party dashes and devices
  • Full closed loop operation
  • Flex fuel capable
  • Launch control, antilag, flat shift and boost by gear all standard
  • Semi sequential injection and wasted spark ignition
  • Spare 0-5V analogue input
  • On the GTR / R32, VVT output can be reassigned to a different function
  • One additional spare aux output
  • 3 spare digital inputs
  • Spare temperature input
  • Compatible with single and multi throttle body (for GTiR) tuning modes
SPECIAL FEATURES
  • This ECU also supports all the functions of the 440 ECU, however for advanced functions such as traction control, additional wiring and/or sensors will be necessary:
  • Flex fuel function – fill it up with gas/petrol or any ethanol concentration
  • Adaptive fuel control (self tuning) – reduces dyno time
  • Traction control function
  • Serial input for wideband O2 sensors (we recommend the MTXL)
  • Serial output for communication with dashes and dataloggers (we recommend the Race Technology units)
  • Headphone port for listening to the knock sensor while tuning
  • Basic closed loop ignition control
  • Closed loop fuel, idle, boost, 2 x variable valve timing control
  • Dual maps (both maps required for GTiR for combined TPS / MAP tuning)
  • 4 weeks later...
  • 4 months later...
FYI, there are instructions in the manual on how to change this from Z32 to gtst and gtr. Very easy. Basemaps also free with the software download (also free)
  • 3 weeks later...
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
