Hey all
I have a 32gtst and i was planning on putting a rb25 in it.
At the moment it has the 20 and is around 170kws and i just feel its lifeless and gutless. The plan was to chuck in a rb25 but then i have toi take it through regency and get it checked, plus upgrade a few things to get it through. is it worth it?
If both engines chucked out say 250kws, will you notice much difference between engines? Its all im looking at for a daily weather it be the 20 or 25.
Just dont know if its worth the hassel as im building a 25/30 at the moment for the track car and i just cant be stuffed!!
https://www.sau.com.au/forums/topic/465900-opinions-rb20-or-25/
The difference between my cefiro (230-240rwkw RB20) and my daily (Stock RB25DET R33 sedan) is huge, on the street.
Cefiro needs revs, and lots of them. It is laggy.
R33 feels like its on boost instantly, comparably, obviously with less up top, which, as GTSboy said, is where it counts for a street car.
Then I drive the missus TT 300ZX and wonder what the F*%k I'm doing with an RB20
Haha.
All depends what you like. I don't really mind the lag, can still putt around off boost, and is fine for the track (drifting). Would piss me off if I had to drive it in traffic everyday though.
  • Like 1
RB25DET NEO, put in ARP2000 studs, slap on a GTX3576 on a TS manifold with divided 0.83 rear housing + all supporting BS.. make 400kW+
Destroy the oil pump from one of there many issues to you throw a rod threw the block and destroy everything.
Too much timing bent a rod? Haha
I always relax on the timing peak torque to keep these stock RBs together. Been doing 370kW on mine for some time, prior to that a good 330kW.
Head gasket is going though, must have screwed it prior through ARP studs. Do about 4 to 5 hard laps and you'll lose coolant.
My old 32 was my daily for 6 years, running 200 odd for most of that time
If you can get a 2530 or similar turbo (I had a 2510) and set it up to run 18-20psi it's not overly laggy and provides good top end
During the same time I had 2 mates with 33's making similar peak power and the extra cc's plus the vct made them a much quicker car everywhere
If I was my car, being a daily I'd go rb25. Even with a stock turbo setup making 200kw it would be a quick daily
  • Like 2
RB30E is where it's at for daily driving :P
In saying that, my stocker RB20 R32 with R34 turbo was a good daily drive, albeit slow, unless I revved it out.
Was averaging 9L/100km because in traffic, no boost until 3,000rpm + slow moving = long boring drives to work and home.
In saying that, NEO6 turbo is a much better drive and decently efficient as well (a relo of mine put one in his R31). RB30 with NEO head even more so haha.
Since your other cars have higher powered engines, put a V8 in your R32.
  • Like 1
More the oil pump has the same crank nose issue on the neo as early 25s and end up with no oil pressure and a dead motor. No tune is going to help that, conservative driving will yet no fun in that. Pointless doing up what's a potential hand grenade without fixing oil control issues first.
Yuh, but Jonny dose-a-holic is a subscriber of the blow-it-up-and-slip-another-stock-engine-in school of thought.  Play engine roulette.  Sometimes you win for ever.  Sometimes you lose in a week.  If you lose, you spend another grand and have another spin.
The alternative is to open the engine, let all the Nissan out and spend $5k putting expensive parts inside.  Different sort of roulette.
  • Like 1
I'm also in the, if it ain't broke don't fix it school of thought. Why spend big $ on something that "may" happen. RB25's aren't exactly rare and there's no premium a week before race wars either:). Plenty of guys out there pushing decent power and tracking stock RB25's without issue. Obviously drift guys sitting on the limiter constantly are more likely to have problems.
Back on topic the OP asked about. A 25 will be better in every way as a daily and 250rwkw will be childs play for it. The low end torque and response being the major difference. Keep the Nissan in and keep smiling[emoji106]
  • Like 1
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
