Hey guys,
i have a 34 Gtt with a built neo, ross 8.5:1 forged pistons, arp head studs etc, I have a set of r35 injectors,z32 and Walbro,power fc, basically all supporting mods but a standard op6 turbo
i have the opportunity to buy a new 3076 with .82 rear for 1600 + turbo smart 45 mm gate for 450, I would still have to fab a dump pipe and I would be stuck with my cast manifold
A friend from Finland who is fabbing a ti exhaust for my bnr34, has offered to make me a kit comprising of a custom twin scroll dual gate t3 manifold, a 'fullrace' water cooled hx35 with 14cm rear and a v band 3.5" dump pipe for $2100 delivered.
My understanding is that the 14cm housing will behave like like a .97 open..
Seems to be a better bang for buck option than the gt3076 route, with a properly designed manifold & dump
My goal is 350rwkw and full boost by 4000rpm
Do you think this is achievable with the twin scroll holset setup?
anyone with experience with the holset's / twin scroll setup's please chime in.
thanks for your time gents
https://www.sau.com.au/forums/topic/465915-holset-hx35-on-built-rb25det-neo/
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
