Hi,
Sorry if this has been answered before, I've spent days googling and reading this and the G35 forum and couldn't find the info but maybe my google-fu is weak
I have a December 2005 350GT coupe, auto with satnav option
Ok so what I'm planning on doing is removing the nav screen and mounting a Garmin unit to the up and down bracket.
I'm thinking while I'm in there I may as well go an extra step and remove the DVD and card reader unit from the upper glovebox.
I see on the wiring diagram there are CAN cables that go into the DVD unit and into a control unit. The control unit I believe is what feeds info to the instrument cluster (speedo etc). I know that this is so the Nav unit can run the navigation and also display the service intervals etc, but what I'm wondering is, if I remove the DVD unit is that going to mess with the control unit and therefore stop the speedo etc working?
My goal is that I'm going to wire in a 12v socket in the upper glovebox and run the Garmin power cable down behind the dash so the power cable is tidy and hidden and all looks factory.
Also hoping I can use the 5v line from the up and down motor that triggers the limit switch in the exisiting Nav screen to activate the 12v socket I'm going to install so the new GPS only gets power when the bracket is up.
Cheers
https://www.sau.com.au/forums/topic/465919-v35-nav-and-dvd-removal/
  • 1 year later...
If the car needs it to run, how do the models without navi and this DVD drive manage?
I bought a V35 with this unit, and it has a double DIN head unit installed, so this DVD drive is redundant, unless I can use it as a DVD drive into the aftermarkets head units aux input?
Is that possible, or is disabling power to the DVD possible, because overtime I start the car I hear that unit going through its search for a disk, annoying.
Or can the actual DVD drive unit be removed from the nav unit?
you need it for the car to run. if there is a disk in it, it will try and read it. just take it out. It shouldn't be trying to read if there is no disc
You may be able to open it up and remove power from the drives motor to stop it from spinning.
  • Like 1
A computer. Needs it to make the car run.
A lot of us have done a swap with a DVD unit in its place. But you still need the old one, and its put up behind the glove box.
Maybe if you put the disc back in it wont try and read it all the time?
I started taking the glove-box out, but gave up as my old knees cant hack it accessing under that dash, apart from it being a bit tight down there and dark. Put it all back, and thought bugger it, put up with a few seconds of rasping noises.
Anyone know a good audio installer that can make the factory steering wheel controls work with a 7" JDM Pioneer head unit?
I have seen universal adapters for this purpose, and wonder if anyone tried them in the Skylines?
Edited by Roger Overson
forgot to mention
  • 3 weeks later...
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
