Hi guys,
Thought I would keep a log of the current build with Josh at Galvsport.
Some of you may have seen it recently.
f1WyhdPyMfBGed7V4vEV1jp5hRtS9RcqQ9fpqd_6
Basic Build Spec:
RIPS RB32 with the entire kitchen sink.
Brad Stacey Cage
Full Restoration with brand new exterior Rubbers/Trims
Genuine Veilside EIII
Billet Merge Collector
GW3884R (AKA6465) street Setup.
CPC Billet Plenum.
102mm DBW Throttle body.
Full Set of Nismo Links
MCA Reds Nitto II spec.
Quaife Diffs
The DriveShaft Shop Axels and DriveShaft.
https://www.sau.com.au/forums/topic/465922-rb32/
  On 23/07/2016 at 2:53 AM, JH32 said:
NIce specs, what's some of the history behind the build?
Expand
This is actually my second GTR after bending the chassis on the first one back in 2011.  It was literally in the last stages of being built to how I wanted at the time (only a brakes  upgrade remaining because they'd sent me the wrong parts). It then sat in storage waiting to be re-shelled, kind of pissed me off every time I thought of it so nothing happened for a couple of years.
Then I bought a shell in 2013 but as I was doing long stints of FIFO at the time, not much happened so I sold the shell in 2015 and was going to part out the first car.
Not long after that, my dad had to have a emergency quadruple bypass recently which put things into perspective. I didn't like how I'd never finished building a GTR so I went and bought another GTR that needs some work and here we are. The first car will serve as a donor car  to the current project although the spec has changed quite a bit since then.
Hopefully everything goes well with this build and I can enjoy it until I am physically no longer able to do so.
  • Like 1
https://www.sau.com.au/forums/topic/465922-rb32/#findComment-7760036
  • 5 weeks later...
  • 9 months later...
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
    • Is actually easier than you might think. Assuming you have a spot, youfab up the branch, then just hang a longer than you can fit length of pipe down from there, and chop bits off piece by piece and decde which length was the quietest/nicest, then just put that length up in the place where it will fit. Clever folk can actually make like a trombone slide type arrangement so you can just play it like an instrument to find the best length.
    • Buy her some ear plugs.   Or, wear earplugs so you also can't hear Jackie whining...
    • Necroing this thread in 2025 to say thanks! The Manual for the m60 still has the wrong instructions and says to only press button 2 with ignition on. You are a champ, thank you.
