Alrighty so now that my jzx100 build is nearing its end I decided to move onto something a bit more sports car like and legendary
So i figured id set out to buy a coupè thats abit more of a sports car, I've had 6 fc rx7s in the past so a series 5 was highest on my list, as was the ae86 hatch and the r32 gtr.
After not being able to find much on offer for all 3 of these models i got a lead on a sprinter shell locally at a reasonable priced, i purchased the sprinter after a thorough inspection, it needed quite abit of work, had abit of rust in the sills and usual door jambs, but it copped a punt in the rear which ended up being the reason i on sold it to someone that wasn't as fussy.
After looking at another local silver sprinter, a gunmetal 89 r32 gtr that was very rough and a 89 s5 rx7 i came across a 92 r32 gtr in Melbourne
The seller was looking to sell to expand his business, it looked promising, i got alot of photos taken especially of the rails as they are a problem on these cars and it looked to check out
I transferred the cash and the freight was aranged to brisbane
All in all it took about 2 months before it arrived which was a difficult wait
I was now the owner of a gtr (scarey if your a toyota person), the previous owner had planned to track this thing so he had removed the engine to do oil pump, water pump, tomei sump baffle and a few other things.
In the process of putting it back in he has broken the rad support , its never a good idea to put these engines in with the box attatched
Also the front and rear seats had been sold, single turbo sold, drivers window switch broken and various other odds and ends lost, so this build will require alot of chasing up fiddly little bits
I am also a stickler for oem bolts, various bolts i notice have been lost and random bolts replacing them which ill need to fix.
Enough talk so heres some pictures
 received_10208189879129015_zpsacibm1qu.j
You can see the broken rad support
received_10208189879449023_zpsk4iqrk3k.j
received_10208190292979361_zpszxuaq6ux.j
Check out the injector wiring and exhaust leak on the firewall
When it arrived in brisbane the morning i picked it up
So the bonnet had seen better days and the cars suppose to come with a brand new n1 bumper minus lip and vents so i picked up an n1 bumper in japan which ended up costing  $900 shipped! And a local genuine n1 bonnet
Out with the old
In with the new
Theres nothing i hate more than cheap Chinese shit parts, the factory wheel was removed and binned by the previous owner, for a fake omp flimsy pos wheel
So i bought a genuine r32 gtr wheel which is inthe process of being recovered right now
received_927124970657983_zps0916rkg8.jpe
Also picked up some genuine n1 skirts
received_10153913413969928_zpsysohf2gf.j
Now all i need is the heaslights and boot lip
Shes going to be slow going but hopefully one of the cleanest gtrs around one finished
Note
Ok well I have actually started this build on another forum, but because of a lack of interest being a skyline on that forum I've decided to move it here, so until I'm up to date most of it will be a copy and past
so bare with me on that
cheers
  • Like 1
https://www.sau.com.au/forums/topic/465941-bnr32-gtr-saving-a-datsun/
So while on holidays i decided to have the steering wheel sorted, ill take a picture when im home of the junky wheel that came in the car but I'm a fan of oem so here it is
Beforehand, all pretty worn
And afterwards, results speak for themselves, pretty amazing
Not really an update but anyway here goes
So i'd made the decision to remove the single turbo setup and ideally i wanted to run a pair of gt2860-7s,
So first thing first i removed the single turbo manifold
I also managed to find a cool pack cover, i really don't understand where these go or why previous owners remove them, but one popped up for a decent price, half of it looks sanded so it looks pretty terrible but this is the base and it can only get better from here..... i hope haha
A couple random pictures
The pair of gt2860-7s, trying to find some info on these, they seem a bit unusual
Serial numbers are 14411-AA403 which is the later model r34 gtr n1 turbos with .42 front housings, somehow they are rated to 500hp the same as the earlier AA401 and AA402 34 n1 turbos with .6 front housings
So sadly the further i dig in this car the more i see questionable workmanship, so I've decided to pull the motor and go over it top to bottom, redo the rocker covers, do a complete vrs kit on it
Have the rad support repaired and whole bay painted while im at it before the cleaned up engine goes back in
Cheers
  • Like 2
Haha it tends to always be the way especially with these old girls
Alrighty then
Sometimes to go forward you need to go backwards, which is a pain but its the nature of the beast
So after seeing questionable workmanship i thought the motor had to come out to check what else was shonky
Half way out
Dirty bish all the way out
Those playing at home, this is why you run at least a full length dump pipe when runninh your car, it makes a f $#^ing mess!!!, studs missing between head and manifold also makes a massive mess, dont do it!
received_958188450884968_zpsxisl6m8b.jpe
So fitted up to the stand looking like a filthy whore, had only just been out but no attempt at cleaning anything at all
So abit of time with acid and a gurney and we have this
An rb26 that looks pretty clean :-)
The intake side is still fully dressed so hasn't been done to the same extent but will be when the plenum is removed
Head has been reco by someone else so I'm just hoping its been fitted properly, i can see it actually has arp head studs like its supposed to
Picked up some factory piping for the 2860s
Also found bolts for cas were incorrect length and munted the cam gear
Im hoping that's the last of the f**k ups
A couple new parts purchases also
ppqjj709-img600x600-14462715602rb5fp1865
Mint Factory airbox from japan
New radiator support section, gearknob, rubber gear boot, number plate bracket, corner bumper brackets, and some other odds and ends
Looks like it had a flogged out patrol gearboot or something
New gearknob, looks like someone tried to eat the old one haha, its not actually grey in person lol something to do with the flash
Not happy with the gear boot or handbrake boot and handle, so they will be redone later on
And i picked up another set of front seats because I wasn't 100% happy with the old ones
 Need to find a rear set to match now as my current ones are abit faded
Hope those following are enjoying it so far
And if you are following please comment  ;-)
Ok next update
There was mismatched sized bolts in everything so i thought it wise to run a tap through everything, amazing how much swarf came out of the threads
I then did abit of a dummy fit of the twin turbo setup, still waiting to find a set of decent dumps and front pipe, sadly can't find anything decent
So then stripped back apart, exhaust housings removed and the whole lot sent for hpc and powder coating
Cam covers and plenum also removed and sent for powdercoating, this is the last time this engine will look this bad under my ownership lol
Ok so NEW PARTS time, everyone loves new parts!
I managed to pickup a brand new n1 front bar and lip!!!! Pretty amazing and glad to be able to fit them to my gtr, also managed to sell off my second hand n1 bumper, lost abit of money on it but that's cars i guess
Some brand new xspurt 1000cc injectors to suit rb26, need to look into how to clean up the fuel rail tho, its looking abit sad, possibly re-zink coat it, anyone done that before?
Power fc pro, z32 afms and a walbro 450 pump
Im tossing up ditching the pfc in favor of a plug in haltech platinum
I'll be receiving the covers and turbo setup back in about a week so stay tuned for abit of rb26 porn!
  • Like 1
well, at least you're on the right forums now. and your engine is in the usual GTR location (on a stand)
It might just be the pics but the timing belt looks worn; unless you know for sure when it was last done it is a good time to do the belt, idler and tensioner bearings, idler stud and water pump
  • Like 1
Haha it seems a common trend, im having thoughts of weather i should build it now or not
The belts new but your right it doesn't look it, so ill be replacing the lot with new oem gear
28 minutes ago, WantGTR said:
I follow your thread on jdmst, its the only reason why i log onto that site anymore lol.
Epic transformation. Im stealing your nismo wheels by the way!
Haha thanks man, alot of people read along there but don't like to contribute
Lol i love the nismo wheels too, took me a long time to get 10s
Cheers
Heres half an update
This is literally the number of stufs that were fitted to the manifold for running 5 out of 12 haha
I can't stand things not right so here goes
Pulled the old studs and cleaned up the surface with some emery paper
Latest revision of studs from nissan japan
I tapped out the threads because they were abit hairy, new studs went in easy as pie
Oem studs fitted up and some multi layer steel gaskets because nissan graphite gaskets are crap and only a single use item
Brand new bar and lip mated up together, looks the goods
Some new parts from kudos, r34 gtr engine ornament and hks intake gasket kit
I dont like to hide the fact I'm not a fan of nissan engineering, and where ever i can I've vowed to toyotaise this datsun as much as i can
First thing is the cam cover rubber washers, the nissan ones don't age well and lose their integrity as you can see in my picture, my rb26 had about 5 out of 20 still intact, the rest had disintegrated
As you can see the toyota part is slightly smaller, these are used on the jz series of engines, they are a third of the price of their nissan counterparts and last much longer (my 2jz still has the original washers on it from factory)
So a handy tip for any nissan folk, i need my cam covers back before i can fit them but once they are back ill show pictures
Hey Scooby, i had it done overseas while i was on holidays and the place was super difficult to find, if your still interested pm me and ill try find the details but itd be easier locally
A few more pics of broken things being fixed
I decided to pull the throttle body assembly apart and the runner that bolts to the head, what do you know reused paper gaskets lol
This is a no no, reusing old paper gaskets is no good, and paper gaskets in general especially on a boosted engine are a bad idea
The previous owner also fitted some silicone hoses under the plenum, im going to give these a chance but if they leak they will be replaced by oem hoses, the kit isn't comprehensive either so i have ordered the remaining old hoses from nissan
It takes ages to scrape all the broken gasket off
Now clean as a whistle
All cleaned up and abit of paint, i noticed the o rings to the vaccum chamber were rather tired, tried to get them from local auto stores but they are odd sized so have been ordered new from nissan
I bought about 14 tridon Hose clamps because i like things to be uniform, and surprisingly just about every hose on these engines is the same diameter
Also bought some turbosmart 3mm and 6mm vaccum line, Every hose on this engine is old and perishing so they are all being replaced
This is basically how its sitting for the moment till my parts are finished being coated
The fuel rail and my newly aquired r34 dumps and stainless front pipe still need coating tho too
So the next update should be a better one with the covers and pipes fitted
Pretty happy with how the loom looks now
So the update everyone is probably waiting on, wondering what colour ill do my cam cover set
So i picked the parts up from being coated, i was abit dissapointed that some parts didn't get done so ill have to take them back, but the parts that were done look excellent
I had to think long and hard about what colour to do the covers for the head, red and black are the common two combos but everything has been done from grey to green and even silver
So what colour did i choose?
Yes gloss white! Something that you don't often see done, the only other one ive seen with white is the powertune white elephant
Theyare literally only just sitting on for these pictures
So it took abit of mucking around but they are bolted down now, you can see the neat little toyota rubber washers
Amazing what a bit of effort and elbow grease does haha
Fitted a brand new cas gasket
And assembled the turbos
I hope this update was somewhat eyegasmic lol
Enjoy
  • Like 6
good to see you fixing all the old dodginess, although I'm not sure corolla spec parts are an upgrade.
the other thing you should do while it is all apart is take the sump off, upgrade the oil pump and put drop some baffles in the sump. Not much extra work or money from where you are now, but great for peace of mind
Lol i don't know about that, i trust corolla parts more than nissan parts personally, that and they look better, do the job better, last longer and are a third of the price, seems a no brainer to me?
If i could toyotaise the engine internals i would haha
Its got a brand new n1 oil pump and a tomei baffle, dont know if that'll suffice for what I'm doing or not tho
Billet oil pump gears would be nice, its a long nose crank engine so touch wood no issues there
2 hours ago, Duncan said:
unless you are racing the tomei baffle is enough, but the n1 pump has had some bad outcomes, I'd suggest aftermarket gears at a minimum and preferably a nitto or tomei pump
Don't forget to recommend a sump extension if going a tomei pump!
I've known a few people to use them without problems, I think if you don't sit on limiter and abuse them they are fine at moderate hp levels
I'm running -7s so it's not going to be any record breaker
I don't like the idea of the nitto and tomei pumps pumping more oil than they need to then having to add resirictors and open up bearing clearances to deal with it
Ideally I'd like to run the n1 pump with billet spline drive gears and a sump extension but that means tunnel boring the mains because rbs aren't precise in the tolerances to run them out of the box
For now I'm hoping the n1 pump will do
Hawkins is running 500kw on a stock motor/pump/sump, if I can go 350-400hp that'll do me
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
