1 hour ago, jmknights93 said:
Where did you order those old style nismo stickers???
I'll send you a pm man
9 minutes ago, SiR_RB said:
Mad work so far !
watching this thread closely, love the attention to detail☺️
Thanks, appreciate the comments
For anyone following along at home i suggest some tissues or even a towel for this update haha
So i got all alot of the cooler pipes and bov pipes back the other day, so i decided to assemble the recirc system
I have a second system because it's a bit over complicated lol
So i kind of freshened up the rubber joiners and brand new clamps all round
Looks heaps better than before
So this is the part where you need a towel
So being a s2 my car naturally had s2 heaslights, they were by mo means in bad shape, especially because gtr headlights are glass
But i went to buy some parts and got a bit carried away with a full wallet haha
Whats in there you say?
A new badge set to suit a crystal white r32 gtr
Brand new door jamb rubber set
Brand new wing gasket set
New c pillar trims, common issue on every r32
And the piece to really put a horn on a Jelly fish
Brand new n1 headlights
Edited by Stephen_rx7
  • Like 5
15 hours ago, Trex said:
This is looking like a fantastic build.
Havent seen one like this is years!
Thanks man, I thought it'd be a regular occurrence on here, I'll need to have a better look around
Alrighty another half an update, nothing majorly significant
I removed the last remaining things from the engine bay, the clutch and brake boosters were a pita because it's sitting on a hoist so access under the dash was limited and uncomfortable
So i decided when i was looking at the gtr i really didn't like the big ugly indicators they had fitted at compliance, no worries Ill contact andrew at kudos and line up a new pair.
received_10208189879449023_zpsk4iqrk3k.j
Well so i thought, it seems everyone crashes these things on the lhs and it means lhs guards are discontinued, damn
So i started the hunt for a good second hand pair, i found a white gtr being wrecked at the gold coast and pounced on the guards!
No holes and better cond bumper mount tabs!
So i decided while i had abit of motivation that i wanted to strip the guards off and everything forward of the windscreen so my painter could paint under the wiper cowel
I was abit nervous about removing these panels because you never know what previous damage or rust your going to find
And I've seen a lot of gtrs at auction with rust in the back corners of the bay
Nuts for the wiper pivots are a little rusty but that's it, no rust on the car itself which is a big relief
The area under the guards will also be painted instead of just being under coated so it won't rust in the future
I was also happy to see no rust under the brake/clutch boosters or under the abs unit
A problem i did have though was the flare nuts in the wheel wells were siezed and rounded off with pipe spanners, even vice grips wouldn't work so i had to cut them off and use special sockets for rounded nuts
Another issue I've encountered is the brake lines don't fit properly, the stud on the upright is too big for the brake line, so you can see the hole next to the stud they used to tech screw it down which is prerty rough haha
Might be an excuse to buy braided brake lines haha
So with cut off brake lines it got me thinking, im going to have to order lhs and rhs brake pipes
But then i got thinking i don't want to put an old abs unit into a freshly painted bay, especially when they are known to leak, so i ordered this
R32 gtr n1 brake master cyl, i also ordered the correct engibe bay clips to secure the lines as well as the 3 brake lines i need to remove the abs unit
I then decided to strip down the alternator to rebuild and tidy up
Bearings are abit tired so they are ordered, and the brushes are shorter than id like so ill pickup some replacement brushes, the pulley has been powdercoated and the casing will be sandblasted and probably cleared
And abit of a cosmetic update
R32 gtr n1 boot lip :-)
Some people love it some people hate it, personally i love it
The guys name was nick haha, he is on here somewhere
the exterior is fine, just the engine bay he abused and dirtied the f$&@ out of
the boot lip is the only non genuine n1 part I have, the Oem ones require holes in the boot, the studs rust which I don't like and also the plastic goes to shit and they bulge out past the boot line
tried to buy a couple genuine second hand and they were very average
Another update
Bulk new engine bay parts :-O
Basically all the stuff that breaks when you go removing stuff from the engine bay
The wiring housing for the cas wiring at the front of the engine
Was broken on my loom
Heater hose clamps and pipe clamps for the carbon canister pipe and brake pipe on the firewall
Abs firewall clamps which funnily enough now i don't need, engine loom p clamp
Engine bay main harness cable clamps
Series 1 gtr horn wire
Fuel line clamp for rhs chassis rail
Nissan calls it a brake clamp but it actually holds the carbon canister line and a/c pipe to the lhs firewall
And 10x dump pipe nuts finally
Been waiting on these for ages
  • Like 2
Thanks josh
Abit of a parts update
fbba8af7f7c057ccdae0c58c66b72848_zpsme3z
More n1 parts, a brand new bm50 non abs master cylinder turned up
8d8e85d3044ef1b9c59aa3f49ce4187b_zpsarpl
Some brand new SSR centre caps, I'm not a big fan of the unusual centre caps in the indy500s so I figured I'd order the latest style Ssr caps
These will be fitted to the Indys once the centre bore is machined to accept them and they are refurbished
93af565a8c15b15ab00958e45778590c_zpsswhd
A s2 gtr horn button to be fitted to my s2 gtr wheel, have to decide which wheel I want to run once the s2 wheel is retrimmed later in the year
19a37e3b74b0131f4f37c7da0e73c3bb_zpsi2xw
Some brand new oem Nissan parts
New timing belt to replace the gates belt that's on there, the gates racing belt is apparently brand new but I'll replace it with new oem for piece of mind
A couple breather hoses for the stock cam covers, and brand new bellhousing bolts as well as some copper washers
3458d47f00afc201172a8d9bb9a96924_zps3fnr
Also a rebuild kit for the alternator, bearing were a bit tired and brushes a bit short so I'll fix that why it's apart
88dae5c95c6316ce4bf36647e08cb45a_zps52kt
And a set of black silicone heater hoses, I'll probably sell these as I've got some oem heater hoses on the way
Hopefully see some of these parts be fitted this week
Ok an update I've been looking to make for awhile, cars rolled out side and gave it a quick hose down to get the dust off
First time it's seen daylight since I've had it haha
Not much of a car at the moment
Painter is semi ready for it, so tow truck booked and on its way!
So she's out of my hair for the next 2-3 weeks
Nismo decal turned up, they actually sent 3 which was awesome incase I stuff one up, looks like it is placed pretty well to me tho
I apologise for some pics being Abit blurry, Samsung phones don't like to focus, I really need a decent camera
A couple more parts back from powdercoating
All my pipe work for the turbos, cam gears, fuel rails and brackets have been sand blasted, and I dropped them off for zink coating yesterday
For anyone thinking of doing the same soda blasting is advised so your parts come out with a nice shine, apparently sand blasting takes the shine off and leaves them Abit dull after coating
I'll be removing the golebys adjustable cam gears and putting them in the bin and fitting up the oem cam gears
Also the alternator housings aren't pictured but I have decided to leave them with the powdercoater to have coated to protect them for the future instead of being raw alloy which soaks up all the oil, grease and gunk which quickly makes them look black
yasu32gtr2000-img600x450-1452555154vfb0z
I wasn't 100% happy with my rear wing, the base mounting plates were a little crusty, so you'll notice in the pics it's missing, it's been sold off
And I've ordered a wing from Japan that looks brand new
yasu32gtr2000-img600x450-1452555155tlzjr
Unfortunately shipping alone is $200 aud to bring it over, but it's hard to find parts in this condition locally, still waiting on this part to arrive
5cc6d8d9833b74cddf0555024ea87e43_zpscorr
0d6beca6498ad5f45a18621f0a1e793a_zps0lea
Nismo floor mats and brand new oem O2 sensors ordered and coming with the wing from Japan
Also last but not least some very exciting purchases of new old stock n1 parts
Brand new n1 bonnet lip, long since discontinued, managed to pick one up that someone had on the shelf, sadly it's grey but it'll be repainted white
And the last known set of n1 front vents brand new in circulation from supplier, will go well with the brand new n1 bumper and lip
Pretty exciting times.
At this stage it looks like a lot of parts
But soon things will come together and parts will be getting fitted
Cheers
  • Like 1
4 hours ago, junkie said:
Damn, this is awesome
I love these "resto" builds. Much more interesting then all out power builds where so much of this stock stuff just gets trashed
thanks man, I feel the same, resto with a few improvements is what I'm about
4 hours ago, reaper said:
How much is the blasting and zincking/powder coating setting you back for all these bits and pieces? Considering doing it with mine.
The blasting can sometimes be more expensive then the powder coating itself
All the pipes/cam gears/ brackets you see there were from memory were about $150 to blast
for the big lot of powdercoating on the previous page I think from memory about 250, engine covers and HPC manifolds/exh housings was around 700
so it's definitely not cheap but it's durable
3 hours ago, jmknights93 said:
@Stephen_rx7 I ordered those stickers from the same place. What was the turn around for you?
Pics and updates look awesome. Whats happening with paint? Anything special going on there?
They were surprisingly quick about a week from memory
for now it's just had the bay painted, I wanna get the engine back in then running and do the complete outside then it'll basically be where I want it
im not too Into special, it's a factory white car so it'll stay the 326 white, it looks great in good condition, I'm hoping to get a bit of wow factor from the nismo additions
cheers
  • Like 1
Alrighty
While I'm waiting on the shell to come back i thought I'd start on some other jobs
Pulled the brush box for the alternator apart, brushes were abit more worn than id like
New brush vs old brush
And thats basically how you re-brush an alternator
Still waiting on the housings and bearing puller to replace the rear bearing
So i removed the twin turbo pipe and clutch pedal, common for people to buy nismo clutch pedals which are basically stock pedals with a couple extra tack welds so they don't break as easy
received_10209554086432998_zpstsn5paj7.j
My fab guy did the splitter mod and stitch welded the pedal with some gussets so it doesn't break ever
received_996185913751888_zpspxvxx9rc.jpe
Last couple hoses for under the plenum arrived and fitted those
New breather hoses eventually became available from nissan, ive had to try to order 3 times as there has been nil stock
You can spy the brand new lifting points, not sure why but everyone removes these from these engines, another item that was difficult to order
One difficult part about building one of these cars is the parts becoming disscontinued, i tried to order some of these headlight flaps but they sadly aren't available anymore
And they sell for 400 a pair for new old stock !
So mine are completly busted and only 1/4 remains
So i needed to find a pair on a r32 being parted that aren't mangled too badly that i can make a template
received_996185773751902_zpsgwdqeenc.jpe
After scouting facebook i found a guy wrecking a r32 gtst and he has these
Should be good enough to make a template and im going to try have a couple sets of these reproduced for anyone interested
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
