So, I went to check on the car, been with the painter for a week, unfortunately was meant to be done this week but hasn't been touched yet
So I'm doubting that will happen
But anyway, got my alternator housings back today
Been powdercoated, I told them not to do inside but sadly they did the whole thing
This presents 3 problems, the rectifier needs to be grounded to the housing for the alternator to work
Bearing clearances are already tight without having thick powdercoat in the recess
The stator is a right fit inbetween the two housings and again the thick powdercoat doesn't allow for it
a9aa7c7f95af62a87b721c0563260cb7_zps9xnj
Bought myself a much needed bearing removal tool, should have bought one years ago, this one isn't excellent but does the job
So you end up with a removed bearing
New bearing on
By this time I've cleaned up inside the housings as best I could, front bearing was a tight fit but it went in
All basically assembled with the stator painted black, normally you'd fit the pulley to the front housing before hand using the vice to stop the rotor spinning, then slot it in together, but the pulley required the powdercoating removed from the centre hole before fitting
And that's basically it
I may even sell this one off and have another crack at it specifying not to cost the insides, see how it goes though
Terrible picture but brand new r34 gtr n1 1 bar adjustable actuators turned up
So they have also been fitted up
Also managed to pickup kudos's last radio surround
bb1eeabae7fc60f3bd74e48442b8481a_zpsqlk6
I believe tour can still get the smooth one from the s1 which is strange, I think a lot of people update to the textured s2 in their s1
I think if I had a s1 I'd prefer the smooth look
Cheers
On 2 August 2016 at 10:13 PM, r32-25t said:
Those lifting points don't come on the car factory and if you leave them on I think they hit the bonnet
Thanks for the heads up, I'll be sure to check that once the motor is in
that'd explain why I had so much trouble finding them haha
So i picked up some parts off my fab guy this afternoon, he does some excellent work
Twin turbo pipe modified with the splitter to stop turbulence
Clutch pedal tig welded at the joins, nismo bracket eat your heart out haha
Rear wing turned up and it's as good as i hoped
No rust on mounting studs or plates and no rust rattling around inside
New nissan strikers and striker covers
New n1 brake lines
Overpriced nismo floormats lol
New ssr 90 degree valves, valve extensions and some ssr lip stickers
And i found out the ssrs require special wheel nuts that are shanked and tapered, never seen anything like them
These suit volk gtc but also suit the ssrs
And brand new o2 sensors
Will have a lot of work cut out for me fitting this gear when this car arrives
  • Like 2
On 4 August 2016 at 7:19 PM, milanr34 said:
Well done and keep up the good work!!
I can honestly just bring a chair some popcorn a drink and just watch people restore cars (no homo)
Thanks Milan, appreciate he kind words
It's something else to watch someone's car come along from where it to started to a piece of artwork in the end
hopefully mine will be worthy of that statement haha
So this will probably be a bit of a long winded update
Went and paid a visit to the painter, his dragging his feet quite a lot as painters do
Cars been started on at least this time, he said he wouldn't need it for more than 3 days, now it's turned into 4 weeks and counting
He seems to think it'll be done this week but I figure in 2 weeks
Engine bay has been cleaned with some strong citrus cleaner, it's the only thing that'd get the soot off, then the bay has been rubbed with scotch Brite, his smoothing out some bits that were modified to clear the single turbo ( basically strut tower was clobbered with a ball pein hammer)
And new rad support is on and bonnet latch upright
So once everything is back to Oem fresh it'll be primed then a couple coats of 326 white rather than the original Oem dust coating of paint that wears through in no time lol
So that's about it for the shell, onto other fiddly bits
Brand new heater hoses turned up
Out with the old, surprisingly still in good shape tho, not crunchy at all, could have gone again
Proper Oem retainer clamp that was missing ordered new
All fitted with proper hose clamps not those Oem Nissan jobs
Dropped off my Oem clutch slave to SSS at brendale (stainless steel sleeving), I could have ordered a brand new slave, but I didn't want to, I believe in stainless sleeving, have it sleeved and the master lasts a lifetime, then you just put a rebuild kit through it
Basically all the old parts, slave was full of gunky dirty shit before hand
Slave looking like brand new, but better
Parts finished being electroplated, some parts came up better than others but they are heaps better than before, and the twin turbo pipe has been powdercoated for the second time haha
Started doing final fitment of the hard piping for the twins, pretty happy it looks better than the Nissan new Oem finish
All the piping on, I'll probably buy another set of the upper water pipes and have them redone because I'm not 100% happy with the finish and they are most visible pipes
From another angle
Close up of the finish on the fuel rail and cam gears
That's pretty much it for now
  • Like 3
Ok a bit of a small update if people are still following
Decided since the fuel rail was finished I may aswell fit the new injectors and the refinished rail
All fitted up with the xspurt 1000cc injectors, looks pretty decent
Tidied up and finished off all the hoses at the back of the motor
So I wasn't happy with some of the condition if some of the parts that were zink coated
So I bought some more gears, twin turbo pipes and decided to even give the banjo bolts a go to see how they'd come out
I picked up a bench top sandblaster so I could prep some parts myself
Before
And after, this is using glass beads, so I'll be interested to see how the finish is being the glass beads seem to clean up and polish compared to sand that pits the metal as it cleans
Box of bits to be dropped off to be zink coated
So there was a couple Nismo parts I want to finish off the additions to the car to make it more era correct and unique
goriguri36-img450x600-1460632591n5zfn510
Rare rear Nismo strut brace which I'll be restoring to match the front one
And something I've been trying to buy for awhile that is extremely rare, so much so that a lot of gtr owners don't know about them
ts180r-img600x450-1460555145mfsmh616062_
R32 gtr Nismo optional rear pods, basically finishes off the exterior of the car, so with any luck next week the car will be towed back from the paint shop and I can't start assembling this engine bay!
Cheers
  • Like 1
Sooooo, went and had a look at the car, no change since 2 weeks ago, frustration.
I dropped the bits off for electroplating that I blasted last week, 10 working days on that so the engine can't really go in the car till thats sorted anyway but still frustrating I don't have the car back
63376a645465a580fc4d4deebb226478_zpsbao4
So I bought some splitfire coil packs, seems to be the done thing, I could have bought new Oem coils which would have done the same thing but rb owners seem to go crazy over these things
c51103227c342f20e88bb6d8b99666b3_zpsdjt1
Old vs new
a7ba4d0163c414d0238c8cee1a0cc722_zpsw0m1
Had a bit of a giggle over this, one of the previous owners must have been illiterate haha
91c683eb83d3ac8e41a34e79d09b90e9_zpsfym2
Stripped the, apart and noticed the bolts were all different lengths lol, blasted the mounting plates so they look new
a531d52007e9754c061f05f13bdaa212_zpsjhsi
All new stainless bolts and washers mounted up
dd35de59625733d7ec9de5f4f91127f2_zpsqcn3
I always thought rb owners were lazy sons of bitches that they only put half the bolts in the coils, only 2 of the 4 holes are threaded haha
565a15276363da4d4131dca4a6a87ef6_zpsg55w
I thought the coil loom was abit tired but it appears to be still good, hasn't gone brittle and shitty yet
Cheers
  • Like 1
Alright what everyone's waiting for some progress on the car finally, it's now back home
To give you a bit of a refresher of how it looked before here's some pictures
This is how it left, sorry state from the previous owner, that's after some effort by me with wax and gerase remover
So 10am this morning I checked my phone and had a message from my painter, it said your gtr is ready to go, I wasn't confident it actually was 100% finished so I got my stuff in order and headed down for a look
Here's what I saw
Surprisingly enough it's painted and looking amazing
So I organised a tow truck to get it home, wasn't able to get it home till late afternoon which left bugger all time to actually work on it which is a it sad
He hasn't painted my clutch and brake boosters so still waiting on those to come back next week then I can start fitting brake and clutch plaster cylinders and hooking the lines up properly, I've started fitting the new line clamps though and some of the hard lines
New n1 brake line clamps on the firewall, only have provision for the one brake line and the carbon canister line
Brand new n1 front lhs brake pipe fitted up
All in all she's looking good, progress will be reasonably slow from here, need to be careful not to scratch the bay and I need to order a lot of new parts as I go to replace worn/crusty old parts which is a it time consuming and overwhelming if you don't do it as you go
And the new genuine gtr wing I finally got a chance to bolt on
  • Like 1
On 9 August 2016 at 0:30 PM, jmknights93 said:
Always looking forward to updates on this thread. Well done :)
Thanks man, as long as people keep commenting I'll keep posting, got over the last forum I was on because it went from being a thread to a blog with no comments
15 hours ago, k_d said:
So much time spent, but so worthwhile!!!
Looks awesome!!!
Thanks man
1 hour ago, niZmO_Man said:
I have a set of those weird tapered wheel nuts, accidentally bought them (internal drive).
Yeh they are weird, they are a shanked tapered internal drive nut haha
pretty hard to find, cost about $210, damn early style 90s wheels
Alrighty update time
Test fitted up the strut brace, looks pretty good
Started putting painted boosters and masters back in the bay
More pieces to the puzzle
Drivers side n1 brake line in
Wiring harness needs some love
Other side of the bay, not much goes on there lol
Bov setup bolted up
received_1027098653993947_zps0rhxsfmv.jp
My gtr key collection, too pretty to cut for the car
Every time I buy a new car I change out the wheel studs, have a couple snap on you from previous owners who don't know how to correctly tighten a wheel nut
New studs
Studs out, I quite dislike the red brakes too
Cleaned up hub with new studs
Hoping to find some brembos to fit shortly so if anyone knows any forsale let me know, otherwise I'll be cleaning up the Nissan factory brakes for the time being
Cheers
Some pretty cool parts for the gtr coming up
e583314eebb226ca5ccef9b5e3083824_zps4dpk
Middle top is a genuine Nissan part I managed to buy still in the packet, discontinued awhile ago
I managed to have these technically drawn and then laser cut out of reinforced insertion rubber
The finished product looks identical to Oem, but won't tear like the original
1ce30a089cb4ca62d115d5fd516a921e_zpsu7pp
Brand new retaining clips, pretty proud of the outcome, it's the finer details that make a car IMO haha
7c0a212bcbc9645ad61c0d4d22583986_zpsodd6
From the front
Some people ask what is the purpose of these, it's meant to stop water/dust/road grime coming through behind the headlight messing up your engine bay
85a2ed76eb1b285f1f5a30eeaaaf32b6_zpsmsok
These are the crappy originals, not of much use
If any r32 gts/gtr guys are wanting a set pm me, running a group buy on some fb pages at cost price to help the community attain some parts that are no longer available
93ff3b48f4aad3b21c1a0b677ffdc9f3_zpshyj0
Also everyone knows I love my old school nismo gear, another addition to the stockpile lol
a1faff817f08c5ad21a28b0550d2e467_zps69gx
And the icing on the cake, nismo lmgt1 wheels, pansaports are for sale if anyone wants some ballin 90s forged wheels, I think between the ssr indy 500rs and the lmgt1 I have enough choices haha
Enjoy
13 hours ago, jmknights93 said:
Ah sweet. Wouldn't mind getting a pair of the headlight rubbers as spare. Luckily mine are still in good nick.
I ran a group buy on them across the gtr sales pages on facebook
there wasn't a massive amount of interest tho, I could run another if we got enough numbers to meet the minimum
the factory ones deffinitely have an expiry date
cheers
  • Like 1
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
