I've had a weakened door lock actuator for a while in my R34 sedan, meaning that one of the doors had to be locked manually each time, not ideal.
I managed to chase down the replacement part from the wreckers and finally got around to replacing it.
This is not a full DIY but here's the general outline, mostly as a note to self for next time:
  1. For instructions on how to remove the inside door panel go here: http://www.sau.com.au/forums/topic/285604-tutorial-r34-gtt-door-panel-removal-guide/ . That guide is for a coupe but sedan front door is very similar. Note to disconnect the window switch plug, push in the clip on the underside of it
  2. Remove plastic lining inside the door. Take care with the gooey black glue, it spreads easily and sticks everywhere.
  3. Remove rectangular metal brace from the door (4 screws) to give better access to the inside of the door end.
  4. Remove the bottom screw of the window slide/guide and jiggle it out of the door.
  5. There are a lot of mechanical arms (thick wire looking things) going everywhere, they are the fun part of this puzzle. Most of them disconnect the same way: At each end, rotate the plastic clip thing to the side first to release it, then pull the end of the arm out of the hole. Remember there are two ends to each arm – only disconnect the easier end, not both.
  6. The door lock/actuator assembly is held in place by the three large screws at the edge of the door where the latch is.
  7. To get the assembly out you'll need to rotate is slightly to get it out of the O-loop in the door lock arm coming down from the top.
  8. I'm pretty sure there's a wiring connector for actuator but I got over excited with wire cutters so oh well.
  9. Once you've got the assembly out you can replace the actuator only, or the whole assembly, depending on what you have.
  10. To re-assemble, follow the steps in reverse. Make sure you put every single arm back the same way.
  11. Test everything before you put the door panel back on: door handle and locking mechanism inside and out, central locking on/off, window up/down. Note that for the window to work you'll have to reconnect the window switch plug.
It took me a while to work out that the window slide/guide needed to come out of the way first. Generally it's an easy job, just fiddly.
  • Like 2
  • 4 months later...
  • 1 month later...
So the passenger door lock is playing up again, annoying. I just pulled it apart but can't see anything wrong; it's a convoluted mechanism but all the arms seem to be connected correctly.
I'm not sure if my replacement actuator is a dud (or just old), or whether there's something else wrong with the mechanism. It seems like the actuator doesn't 'trigger' consistently when the central locking is engaged or disengaged. I wonder if it could be a power/wiring fault...?
Anyone else had this issue in their R34, any suggestions?
  • 3 months later...
Hey man, yeah I accidentally found my front passenger door in my 4 door r4 was not locking or unlocking it I pushed the locking tab inside the car. I stripped the door car off the stumbled across your walkthrough which I must say is very good and easy to follow! My actuator doesn't seem to move much and sometimes only one way, is this what you had? My mechanism seems tough too though but I've blasted it with silicone spray.
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
