I've had a weakened door lock actuator for a while in my R34 sedan, meaning that one of the doors had to be locked manually each time, not ideal.
I managed to chase down the replacement part from the wreckers and finally got around to replacing it.
This is not a full DIY but here's the general outline, mostly as a note to self for next time:
  1. For instructions on how to remove the inside door panel go here: http://www.sau.com.au/forums/topic/285604-tutorial-r34-gtt-door-panel-removal-guide/ . That guide is for a coupe but sedan front door is very similar. Note to disconnect the window switch plug, push in the clip on the underside of it
  2. Remove plastic lining inside the door. Take care with the gooey black glue, it spreads easily and sticks everywhere.
  3. Remove rectangular metal brace from the door (4 screws) to give better access to the inside of the door end.
  4. Remove the bottom screw of the window slide/guide and jiggle it out of the door.
  5. There are a lot of mechanical arms (thick wire looking things) going everywhere, they are the fun part of this puzzle. Most of them disconnect the same way: At each end, rotate the plastic clip thing to the side first to release it, then pull the end of the arm out of the hole. Remember there are two ends to each arm – only disconnect the easier end, not both.
  6. The door lock/actuator assembly is held in place by the three large screws at the edge of the door where the latch is.
  7. To get the assembly out you'll need to rotate is slightly to get it out of the O-loop in the door lock arm coming down from the top.
  8. I'm pretty sure there's a wiring connector for actuator but I got over excited with wire cutters so oh well.
  9. Once you've got the assembly out you can replace the actuator only, or the whole assembly, depending on what you have.
  10. To re-assemble, follow the steps in reverse. Make sure you put every single arm back the same way.
  11. Test everything before you put the door panel back on: door handle and locking mechanism inside and out, central locking on/off, window up/down. Note that for the window to work you'll have to reconnect the window switch plug.
It took me a while to work out that the window slide/guide needed to come out of the way first. Generally it's an easy job, just fiddly.
  • Like 2
  • 4 months later...
  • 1 month later...
So the passenger door lock is playing up again, annoying. I just pulled it apart but can't see anything wrong; it's a convoluted mechanism but all the arms seem to be connected correctly.
I'm not sure if my replacement actuator is a dud (or just old), or whether there's something else wrong with the mechanism. It seems like the actuator doesn't 'trigger' consistently when the central locking is engaged or disengaged. I wonder if it could be a power/wiring fault...?
Anyone else had this issue in their R34, any suggestions?
  • 3 months later...
Hey man, yeah I accidentally found my front passenger door in my 4 door r4 was not locking or unlocking it I pushed the locking tab inside the car. I stripped the door car off the stumbled across your walkthrough which I must say is very good and easy to follow! My actuator doesn't seem to move much and sometimes only one way, is this what you had? My mechanism seems tough too though but I've blasted it with silicone spray.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
