Was looking at replacing the stock rubber joiner hoses on my r33s intake piping, to silicon ones.
I need:
-2× 60mm 90° bends
-1× 60mm -> 65mm hose approx 100mm in length
-1× 70mm hose 70mm in length
- 1× 60mm hose 110mm in length.
I have tried to look for info and where to get silicon joiners of these sizes from, but i cant really find anything
just after some suggestions as to where i can get these silicon hoses and what brands to go for (is sca or autobarn brand good?). Also will 63mm (2.5 inch) fit over 60mm and 65mm tubing without any issues?
I appreciate any help, and im located in melbourne west suburbs.
https://www.sau.com.au/forums/topic/465959-r33-gtst-silicone-turbo-hoses/
Stock is fine. Are they leaking?
cant find silicone joiners? Have you looked? If you're replacing them use good quality clamps too..
ebay and/or justjap for starters will have what you're looking for in all sorts of colours.
I dont think they are leaking. Just looking really worn and for preventative maintainance for an upcoming tune.
I found some aeroflow hoses on ebay that look good.
Does anyone know if 63mm or 57mm hoses will fit 60mm piping properly. Or do you need 60mm hoses specifically?
I purchased quite a few of the hoses I needed from RP Wallis (Spareco), http://www.spareco.com.au.  They are over in Oakleigh so unfortunately not local to you.
The actual website doesn't have the full info on the lengths of reducers etc but the below link has details on their  black silicone hose range.
http://spareco.com.au/documents/pdf/Performance Hose 22-02-2015.xls new.pdf
When looking to fit smaller hose over a larger pipe don't forget to check the barb diameter of the pipe.  You first need to get the hose to go over that.
Good luck
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
