I am selling my pride and joy to make a move over seas. This car has been my daily for past two years . ive done some small modifications to this car . But kept it clean and as stock as I could . please don't hesitate to call or message me and come have a look . $8500
car has just jap front mount intercooler
just jap full stainless exhaust system
hicas lock bar
rear adjustable camber arms.
D2 street coilovers allround
eboost street boost controller running 9 and 12 psi
Work VS-KF rims front 9.5 rears 10.5 wide 17 inch
federal 595s on front cheapies on rear
shimmed diff
cold air induction to pod from front bar.
apexi pod filter with plastic box sarround.
turbosmart bov plumbback
2 motor got put in at 133000 kms upto 15400  running great. got put on dyno by jdm garage at capalaba motor repairs. made 264 hp at wheels.
kenwood stereo . aftermarket speakers in doors and parcel shelf kenwood. kicker amp 5 way and sub.
momo steering wheel and gear knob.
https://www.sau.com.au/forums/topic/465970-for-sale-r33-skyline/
  • 4 weeks later...
  • 4 weeks later...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
