Hi all , I have an idle issue that comes and goes - mostly stays but occasionally rights itself . Moving timing mixtures around achieved zip but still have the irregular idle and occasional high idle and or stalling issues hot .
Got sick of this and had the engine leak down tested which showed air leaking out the exhaust . The fact that the idle comes good some times must mean that it doesn't have a major valve or seat issue because they don't fix themselves . SK has suggested a sticking hydraulic bucket and given the costs of removing/rebuilding heads checking no 2's exhaust side buckets seems logical .
Is this not an unknown problem for a 20 yr 163K old 33 25 engine ?
I don't like the sound of engine oil flushes but the thought of a couple of short runs with high detergent diesel engine oils may be ok .
Thoughts ?
Cheers A .
Couple of different possible approaches.
See if a flush treatment makes any real inroads to the problem.
Run diesel spec oil - Rimula, Dello or similar and see what happens.  Don't know why you'd make it short run, new oil is new oil and you might as well give the detergent time to work its magic.
Lift the cams and buckets, spend a day disassembling  and scrubbing the lifters and then reinstall.  Quite a bit of time but bugger all expense if it's a home job.
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
    • Awesome! I was thinking S14 since they are longer. I'll give those a shot. Thanks for the input!
    • Far out, that thing looks like some loose fun!  Nothing beats the rawness of a filthy old Nissan with zero aids to keep the wheels pointing in the right direction like modern "fast" cars!
    • If there is no ridge at the inner edge of the battery tray (ie the battery tray is flat until it rolls off the edge into the open space of the bay), then no, it won't matter if it overhangs. If the battery would be propped up by any ridge, then that wouldn't be ideal. The bottom of the battery case would not be sharing the load. It would be concentrated on one end edge and a line across the bottom where it contacts the ridge. And possibly it wouldn't fit under the locking clamp either. I only upsized my battery to the max because: I sometime have to leave my car undriven for weeks at a time while I am away for work. On the previous battery (replaced a couple of months ago) I had to leave it undriven for months at a time!! I sometimes abuse the battery by running the stereo up loud for many hours while I wash and polish it. This is how I realised that the previous battery was on its last legs, because it got to the point where it was too weak to start after a couple of such. It was 7 years old though, so, fair play. Supercheap had a good special so the X was only ~$250 instead of ~$320, which seemed sufficiently less painful. I had already been using NS70 for the previous 2 batteries for most of the same reasons as above. The X is just the final boss level. I was contemplating going LiFePO4. But it's like $900 to do that properly, and while you save >10 kg of weight, you can likely only expect a couple of years longer life. So meh. Maybe when the price comes down further. Although, in ~7 years when I have to replace this one, I might not be allowed to drive such an anti-social vehicle anyway.
    • If I get a larger battery and it hangs off the edge of the frame rail, would this be an issue? With FMIC a lot of people downgrade their battery size due to less room for shit, was wondering if it would affect anything but it would still be tight via the clamp.
