I have a r33gtst that is booked for a tune tomorrow.
I have all the supporting mods like r34 highflow, power fc etc.
My goal is about 240 atw
I bought a 1000cc topfeed xspurt injector kit from scottynm35 and even though i assumed they were too big, i was told that they are a much more modern design, can flow well at all power levels and therefore would be suitable for my application.
however the tuner tells me they are way too big and will not be suitable for my goals, he told me he can safely run the stock injectors by upping the fuel pressure with my aftermarket fuel reg.
What do you guys think?
Thanks
https://www.sau.com.au/forums/topic/466010-1000cc-injector-question/
Strictly speaking, they are too large.  You'll only need ~1ms pulse width to idle on petrol and you therefore have very little ability to tune the idle mixtures.  But it will work.  Idle may be slightly fluffy, or it could be perfect.
On E85 it would be easier.
But what you were told by others than your tuner is true.  They will work, and they will allow you to go E85 later very easily.
I shudder in horror at the thought of jacking up the fuel pressure to achieve 240 rwkW on factory injectors.
  • Like 1
Run the 1000ccs, technology has already advanced so far over the last 10 years, they'll be fine
Upping fuel pressure with stock injectors will only lift the headroom by so much over the 200rwkw, works fine but stresses your fuel pump and affects injector lag time anyway
My main concern is, will the car run perfectly on the 1000cc injectors? i dont want it to not idle well or run just "fine".
I will speak to the tuner later today about it, but its looking like i will just cancel and wait a bit longer.
it definitely did not seem right to just up the fuel pressure on the stock injectors. The thing is the tuner is very reputable among the skyline and silvia community and i have heard nothing but good things about him.
If your tuner is smart, and say in the event those milled X-Spurts (I don't have experience tuning them) don't idle well on 98RON, you can drop the fuel pressure to say 2.5bar with the vac hose off on idle (then connect it back once you've finished setting the FPR).
This means now you can run higher pulsewidths and have the correct amount of fuel injected to maintain the idle and AFR of your choosing and you have plenty of headroom for the future.
I've got 1000cc IDs....no issues on idle.  I'm pretty sure there about about 1,000 others on here who'll tell you the same.
Keep the IDs, get a new tuner.
1 hour ago, vxsr33 said:
Called up chequered tuning and they said it would be no problem, so going for a tune with them. :-)
i was told the new injectors dont have filters though. Does anyone know where i can get some? (Dont know much about injectors)
Very good plan :)
Trent is good, he will sort it out. Seen several maps most of which are very good.
Seen big tuning shops in Sydney with tunes that could be done by a 2 year old holding the number 8 key.
  • Like 2
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
