1990 R32 GTR   $16000.    Rego’d to Feb 17.
I’m the 2nd owner, had her for 6 years and done no miles as she lives under tarps in the shed.
http://s200.photobucket.com/user/geoffree/media/IMG_4918_zps28zlf33x.jpg.html
My plan was the keep her forever but circumstances have changed, so there you go.
Previous owner also did no miles, another old codger who tinkered with her in his garage for 5-years while the daily lived out on the street.
Has the usual dash bubble and yes the 125,000 on the clock doesn’t match with wear on steering wheel etc.  Didn’t worry me, she’s a 25 year old import after all.
Paint looks good, resprayed by previous owner, some stone chips. New battery, tyres like new.
Has a towbar for the Hobie, NOT for anything heavy or you’d tear the arse right off.
Everything except the clock works, HICAS, ATTESA all the original Nissan gadgetry is still there, I wanted to keep her stock.
Has HID’s on low beam with relays and diode so low stays on with high.
Aircon is cold and has the thermo fan mod.
Still has the boost restrictor in the yellow hose.
Engine runs sweet as, but she’s worn. Running around 145-150psi cold and down to 135-145psi hot.  No smoke, gets Valvoline synthetic oil changes even though the old stuff is brand new.  Stock gauge goes way up to 6+ on cold start, drops to 4 once warm. Will sometimes go low and then return, clearly needs that new sender I bought, but haven’t got around to fitting.
Previous owner had the cam belt etc done but she had cam seal leaks by the time I got her home so I re-did all that, no leaks now.
Car hasn’t seen over 4000 from me, I short shift into 5th at 60 and away she pulls.
Interior is tidy, has scored some new plastic trims on birthdays, driver’s mat is worn but I’ve got spares.
Came with an M80 noise maker and a club steering wheel lock.
Basically a very standard car, straight chassis rails, no modifications apart from exhaust.
Comes with odd spare bits/pieces collected over the years. PFc and boost kit, never been fitted. Have a set of silicon coolant hoses that I also never got around to fitting.
Located Gympie        Ph:  0403 489540
Email:  [email protected]
Walk around videos:
http://vid200.photobucket.com/albums/aa310/geoffree/GTR 1_zpsefr1j7zo.mp4
http://vid200.photobucket.com/albums/aa310/geoffree/GTR 2_zpsjxnzwdqq.mp4
http://vid200.photobucket.com/albums/aa310/geoffree/GTR 3_zps7dz3gjib.mp4
  • Like 2
https://www.sau.com.au/forums/topic/466014-sold-r32-gtr-16000/
Factory thermo fan comes on when aircon is activated.
A diode is fitted between the aircon relay's output across to the trigger of the thermo fan relay.
They're mounted beside one another in the engine bay fuse box so a simple task.
You'll find the aircon runs cooler especially in city traffic.
  • Like 1
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
