This is probably going to sound odd....but assuming you are doing a rebuild but want to keep the price down, check out the cost of brand new pistons and rings from nissan, they were quite reasonable last I checked.
Also FWIW, rods are generally reusable (and will be obvious if they aren't), and so is the oil pump unless the motor spun a bearing. Second hand oil pumps are a minefield because its hard to tell if they are in good condition
Yeah sort of, going to try 26 internals in 25 block so just a mockup/low cost rebuild as a test to make sure its going to work, pistons are the main thing I need at this stage I think I seen new OEM pistons were about 100-150ea so not far off just going forged but a bit more than I would like to spend considering its just a trial at this stage.
As for the oil pump I accidentally broke the housing.
  • 3 weeks later...
