My r33 gtst has no compression in one of the cylinders and low compression in the others, so i have purchased an r34 gtt bottom end to put in. Ive never done something as big as a rebuild myself (will have mates to help out though).
My goal at the end of this is a freshened up motor and a safe and reliable 250rwkw.
just after a list of parts i will be needing or any advice in general. Should i get new piston rings?
And with headstuds and gaskets should i go for aftermarket performance parts or just standard nissan?
Thanks guys
https://www.sau.com.au/forums/topic/466058-rb25-neo-bottom-end-rebuild/
Stock engine can easily handle 250rwkw, been running the same power and 20psi in my R33 for like 4-5 years now.
I wouldn't bother doing anything, save the time and money and just buy a neo engine or a stock Rb25.
You will probably get the same answer from a lot more people.
Um....Neo pistons suit a head with a 51cc (or something like that) combustion chamber volume and R33 pistons suit a head with 63cc (or something like that) combustion chamber volume.  Horrible compression ratio problems will ensue if you try to use one with the other.  In one case you get compression like in a 1932 Fergussen tractor.  In the other case you need to use rocket fuel to stop it from pinging itself to death.
Well, yeah, you could.  But once you get to that level (ie dismantle, machine the bores, get pistons, balance rotating assembly) you are no longer doing the simple "buy this half and bolt it to that half" build that your OP looks like describing, and you are now into a build that has enough work in it to justify doing stuff more thoroughly.
You'd be better off getting a Neo head or getting a whole Neo (or a whole 'nother R33 engine) and selling on the short motor you already have.
  • Like 1
Or rb30 bottom end and bolt your head on. Will gain a heap of torque and probably work out cheaper overall.
Hmm, would consider doing this, but how hard is it to do? im assuming there is a fair bit of machining and custom work involved? I have a budget of around 2k max. I will check out the rb30 conversion threads though.
Thanks
The runners on the R33 intake manifold are larger so would create a step, pretty sure the Gasket is identical on both heads though.
So i would probably need to get an r34 plenum and intake manifold aswell then? Seems like it would negativey impact the performance of the motor otherwise.
Yeah im not sure if its an issue or not, maybe the head can be port matched or just go the R34 manifold.
You'll need top feed injectors and rail if going neo manifold, plus possibly an adaptor plate for the IAC ( i did), plus R33 throttle body needs modified.
Ports are the same, seems strange they'd bother to make the head/ports different but then use the same gasket?
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
