Hi all , I'm curious to know what you gain and lose in an R33 spec RB25DET with these cams . I've had them for a long time and can't remember what it was like to tune a car for road with standard cams . Earlier on I had a PFC/Z32 and 740 Nismos and GTRS dryer where as now doing a bit better in those areas .
Even so I just wonder what you lose in idle quality and drivability right down low . I know that 256 degree cams aren't exactly wild but the standard ones are from memory 240 and I image timed to have a bit less overlap .
Also I'm curious to know if moving the cam timing around does anything for Poncams , exhaust is easy enough and inlet apparently with a bit of mucking around .
Gotta run cheers  A .
Cheers  A .
https://www.sau.com.au/forums/topic/466083-256-rb25-poncam-experiences-plz/
3 minutes ago, discopotato03 said:
I don't suppose anyone knows what the actual opening and closing points are valve timing wise , I wouldn't mind knowing what the overlap period is .
A .
http://www.rhdjapan.com/tomei-camshafts-poncam-rb25de-t.html
scroll down to your engine of choice.
  • Like 1
From the R33 Engine Workshop manual .
Bear in mind variation in inlet cam timing .
Inlet 0-60 inactive (0+60 +180=240)
Inlet 20-40 early   (20+40+180=240)
Exh 57-3               (3+57+180=240)
These numbers line up with the 240/240 durations and I thing the lobe centers were 120 inlet and 117 exhaust .
Note the overlap timing would be (inactive) 3 degrees and (early) 23 degrees .
A .
After trying a couple spots and seeing dyno results I'd say to get a decent shift in power earlier I had the inlet advanced so far It had no power at idle. I even had throttle adjusted so low as vct under 1000 would stall.
I now run inlet as recommended. Need to experiment with exhaust timing next time it's up for a tune
What kind of general idle quality have you had with it at the recommended setting?  Does it sound at all "cammy"?
Not noticeable now. It was hunting when warm from 500-1100 when the idle screw was too far in but it's smooth now.
like whats his face said, there aint much difference from idle and down low infact its better everywhere, sure the idle changes slightly cause its larger lift and duration but its not a severe change ...just do it man. u wont regret it!
ps.. wow this place changed alot .. just logged in today and its like a ghost town. saw a few tumbleweeds on the home page..
Was hoping there might be the slightest hint of "bigger cam" sound at idle, not necessarily lopey or anything but I like being able to tell there is a bit more going on than stock haha.  Was pretty sure performance wise they'd be a bit of a treat :)  Cheers!
Was hoping there might be the slightest hint of "bigger cam" sound at idle, not necessarily lopey or anything but I like being able to tell there is a bit more going on than stock haha.  Was pretty sure performance wise they'd be a bit of a treat [emoji4]  Cheers!
Closing the idle screw down I can get it to hunt as hard as a big v8...but I sound like a tool when at the lights and can't take off without throttle
you can nearly make Poncams go "brap brap brap" purely for wank factor.. just drop the idle timing down to about 8~10  and lean out the AFRs hahaha
(everyone reading this, please don't do it)
  • Like 2
I thought that might be the case.  Most of the aftermarket cams I've tuned for have been big enough (read: 280-300+deg) to do it anyway, good to know you can do a bit with wee 256s - thanks, Johnny ;) Dose on!
Each to their own.  Hate dose, love a hearty idle!   If you can get a hearty idle with a small cam, win win.   The cars with huge cams are NA race motors, btw... huge boost and dose don't apply.
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
