It was retarded not advanced . The idea being the exhaust valves open and close 2 degrees earlier so the cylinders blow down fractionally earlier in their cycles and the overlap timing is a little shorter .  So instead of the valve timing being 8-68 63-13 it would be 8-68 65-11 and the overlap duration 19 rather than 21 degrees .
I imagine they set the cam where they wanted it with the crank at TDC , then moved the crank with the modified pulley so the cam would be in the normal position but with the crank 2 degrees after TDC . Tighten the four bolts and cam timings finished .
A .
4 hours ago, Dose Postman STFUU said:
brap brap brap bro :)
Edited by discopotato03
Presuming you've had something done with the head?  Pretty economical with the detail Adrian.:10_wink:
Do a bench test and see for yourself what happens to injector spray patterns with bigger base pressure.
Takes the guesswork out of whether you need to listen to what "people" say.
Probably going to be hard to beat a Walbro 460 if you need a new pump.  Contact Mafia for some comments/experience on what works well and how to control the pump to best effect on a road car with Link/Vipec ecu tricks.
I think the buckets were fine , just a few RS exhaust valve guides . If they don't line up with the seat they don't seal too well . Was ported first time round and had Ferrea (sp) over sized exhaust valves fitted . Head was O ringed to make the OE gasket reliable with extra heat and pressure . Std springs shimmed for a few extra pounds .
A .
ok so cams are in, fitted to standard positions, no adj. gears...due to other work also being done to car over last few weekends, haven't done heaps of driving as yet or fully retuned, but impressions so far - idle is a little bit rougher but nothing overly noticeable. If you're giving it low throttle, standard cams win as there's a slight loss in pickup. If you're giving it medium or more throttle, the 256's are noticeably better although haven't even given it full throttle yet.  Looking forward to retuning and seeing the end result.
^^ Andy the truth is for most cases there's far more gain in having optimised inlet, exhaust, and cooler piping than there is cams.  Comments from Stao in his Hypergear thread bears this out.
But changing to these baby upgrade cams sure isn't going to hurt.  Going to be interested to see your results.
The best explanation I have is that aftermarket cams in a street car get you the last 50 Hp , not the first (over standard) . I think there are many better mods to make initially than cams in either flavour RB25DET . Better easier bang for buck .
I just happened to go that way since I opted for a second head to modify , saved downtime , and had it all done together . I also opted to have that head decked to get the highest practical compression ratio without making it unreliable , supposed to be around 9.2 - 9.3 to 1 . Not really a relevant comparison but I was told at the time that the GMS GTRs ran about 9.6 to one esp after CAMS forced them to reduce boost to make it "fairer" for the iron ox taxis .
I now think that lack of exhaust valve sealing and fuel pressure issues were ganging up on me , first issue fixed and a new pump shortly (no time atm) .
A .
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
