  • Replies 165
So confirmed starters...
1. Snowman - accom & both days (Fri and/or Sat night?)
2. IceSupra - accom & both days (Fri and/or Sat night?)
3. Adzmax - accom & both days (Fri and/or Sat night?)
4. Roy - Fri/Sat night accom and both days
5. skylinegeoff - Fri/Sat night accom and both days
6. Scotsman - Fri/Sat night and both days
7. ferni no accom only Saturday
She looks quick...heres hoping its dry :headspin:
yep - will be me and the mrs as well if theres room for both nights. I've also got the bitch along too (thats Gerald). We have paid up for both days already.
I'm definitely not driving up Sat morning. Must stay there Friday night. We have 2 options to meet up beforehand. We can either meet at my place as is its 99% on the way (just down Thompsons Rd) - or we can meet at the huge service center on the corner of the gippy freeway and Thompsons Rd (BP, Macca's and Red Rooter)
BTW - does anyone know what the deal is with passengers on the Sat? Can you take them?
Also - had to have a laugh. Current forecast is for 10deg in Melb for Sat. Which means PhillIp Island will be about 4deg. LOL.
Hope the meterologists are wrong (again).
...Mmmmm hope not rain or I wont be going out I tell u now :P
Ive already paid the $250 so rain wont be stopping me from heading out, actually gives me a good excuse to help explain all my spins. :headspin:
If its heavy rain though ill chicken out and keep my speed to about 150km/h :) on the straights....still no way its going to rain on my first track day with the new turbo setup ;)
Just Remembered, i think i need a Fire extinguisher right? and it has to be attached in cabin somewhere - anyone suggest an easy place without doing too much damage to the interior of my car? :)
What about secondary bonnet restrant? if i bring some rope (how thick/what kind?) i can just tie it down can't i?
And what about something to do with the tyre valves? have to be metal or something?
Ferni,
1 - Fire Extinguisher - maybe speak to Chris (Scotsman) as to where he mounted his. I'm sure he didnt drill any holes. Also - if you haven't bought one yet then K-mart is the place to shop. You'll buy the same extinguisher that they have at race shops for half the price. (mine was $29)
2 - skylinegeoff will be best to answer this as he uses rope.
3. Steel Valve Caps - - go to Autobarn and get them - should cost about $7.
Just out of curiosity - is there anyone thats coming for both days that hasn't payed yet? My co-driver may be pulling out so I might have a paid up (and discounted) entry.
I use a plastic coated steel wire rope from an eye on the bonnet to the tow hook on the chassis. My fire ext is mounted just under the front of the right rear passenger seat where the drilling holes cannot be seen if I remove it.
Roy, book me for friday night and sat night :)
silly question, what are Steel Valve Caps ? and what are they for?
are they just the screw on caps that go over the valves used to pump up your tyres? if so why do you need steel ones?
skylinegeoff: i may have to ask you to show me where to tie the rope - where did you get yours from?
does the fire ext come with everything i need to mount it in cabin (ie bracket?)
You can mount an extinguisher without drilling any holes in a 33 by using the bolt that holds the bottom of the rear seat.
This is what I have done and what I told Chris to do - which Im pretty sure he did do.
The k-mart extinguisher comes with the mounting braket yes. All you need to do is unscrew the bolt and put it back in with the braket in place. It makes the extinguisher a tight fit but it can be closed.
Steel valve caps are exactly that. Why you need them Im not 100% sure - maybe they just want everyone to have a little bit of rice on their car? I dunno (its probably more to do with tyre pressures or something scientific but I like to believe its for the rice factor)
Yes, Mine is secured using the bolt at the bottom of the rear left seat.
I think whatever type of extinguisher K-mart have will be suitable (cant remember contents)
It comes with everything you need.
Rain is probably better for first track day people. It makes you go slower and you learn a lot quicker where the edge is. You learn where the car will start to move and realize how far you can push it. Don't let rain spoil you day. You will have just as much fun and because you wont be going 9/10ths you wont do damage.
Andrew, your making this harder than it needs to be! Follow these steps and you'll be right.
Step 1. Go to K-Mart.
Step 2. Find the fire extinguishers (they only sell about 2-3 of them)
Step 3. Select the cheapest 0.9kg one they have. Should be in a cardboard box and come with a black metal bracket.
Step 4. Go home and attach it to the lower rear seat mounting point.
Step 5. Get a beer and congratulate yourself on a job well done. (I know you don't drink but this final step is an important one) :)
    • Rear doors central locking wiring removed and cleaned. See the first 8sec video of when it’s filled with river silt. its a snip of what I’m up against. front and rear doors complete now. Maybe another day removing carpet and bits and pieces. Then the re assembly begins. 🤙 att.DqweJqhY5MZiZYQDVMhn3LtvdD1RBZ7TBG4f2s7W1zM.mp4 att.lFuN22MZEowqCbFAXoDw009r2gHL76ChMVfxMfBX-uk.mp4
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
