Hello SAU!
Recently my gauges and cluster stopped working all the sudden on my R34 GT-T
I've checked my alternator voltage and measured at 11.3v while car is running. Just wondering if anyone else has the same problem? or/if its only a fuse, don't want to go buying an alternator for nothing.
any help is much appreciated, thanks!
https://www.sau.com.au/forums/topic/466098-clustergauges/
  • 2 months later...
It's happening to me ATM , sometimes it works and other times when I'm driving my speedo meter and rev just drops to 0 ! Not sure what the problem is, fuse is fine, got new battery. Still having the issue, at the moment I'm just using a GPS speedometer on my phone to keep track of my speed on the road zz
https://www.sau.com.au/forums/topic/466098-clustergauges/#findComment-7786303
Intermittent problems point to a dodgy connection or bad earth etc. I would check the plugs on the back of the cluster for a start seeing as both speed and revs are sent electronically to the cluster. Check the wiring etc while its out
You dont have a power fc hc or something you can check to see if the ECU is getting reliable signals from both? That rules out a problem on the sensor end (although it would be rare to get both happening at exactly the same time)
https://www.sau.com.au/forums/topic/466098-clustergauges/#findComment-7786502
  • 3 weeks later...
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
