  • Replies 75
  • 4 months later...
OK - found the right thread to post my wheel question - thanks for patience while i find my feet in these forums...
My question - is there any offset that will allow 18x9s to fit at the front of Stagea RS Four without rolling guards??
I dunno much about offsets - but found some nice rims 18x9 +45offset 5x114.3...
any of u fellas in the know able to confirm if any chance with 18x9s at front on Stageas??
Thanks,
Adam
Thanks guys
Gary you run 18x9s up front as well? What offset are those rims mate - LOVE to know so I can look for that offset???? (as long as they are within +27 to +39)
I have been trying to research this offset shite all day and think Ive finally worked it out...
There are lots of car owners out there that are able to FIT just about anything... but the common conclusion by wheel people (found some posts by aussie rim manufacturersand others) is that you should wherever possible stick within about 6mm of stock rim offset either way as that is the general range within which the suspension structure and everything is manufactured as being able to balance and run properly. Outside of that you really start to experience unusual and uneven loading and wear on joints, suspension, etc etc because too great a proportion of the rim width and weight is outside of the intended line and all the angles and suspension tuning and design is put out. This is in line with the previous posts in this thread that had offsets between that range from the stock offset of +33 (+27 to +39). Manufacturers or wheel manfacurers recommend the varying offsets when there is more room on either the inside or outside of the rim of a particular car make when fitting wider rims (and also why spacrs are used sometimes when people score a cheap wide rim that has an incorrect offset rubbing in the INSIDE structure or suspension but theyhaveroom on the outside - the spaer push the rim away from inside). So yeah the other guy from SWAT running +45 offset is either happy risking added wear/damage, or has had his entire suspension and joints etc modded to deal with the new load shift. So while you might be able to fit 17x7 +16s, or 18x9 +45s on the car - be ready for possibly weird handling and unusual wear and damage.
Thats basically what I gathered from an entire days reading!! So while it would have been nice to whack on the second hand Volk F-Zero 18x9+45s that I found on there - Id be compromising the car (and possible legality) by doing so :D
But then again its late - and I could have comprehended it all wrong :Oops:
Made sense to me last night when I read it and still makes sense this morning...
The idea of spending a few thousand on rims that don't fit the car, then having the guards rolled so that they do fit while adding a structural risk to the handling of the car just sounds silly and expensive to me...
Of course you see young kids who have done it - nothing looks funnier than a civic with big rolled guards and covered in 'rice' stickers with the standard steel rims on as they have no doubt been sent over the pits... just silly, expensive and fugly if you can't even keep the rims on legally... :D
Just phoned a couple of the bigger import wheel and tyre companies that do skyline fittings for a straight plain english answer and all concurred with the info i found above that those wheel manufacturers had posted...
TO AVOID WEAR AND DAMAGE TO SUSPENSION/JOINTS/ETC STAY WITHIN 7mm ABSOLUTE MAX VARIATION (6mm and under better)... so assuming you guys are right and the stock 16" rim offset is +33 (does it say on the rims - can anyone double check?)... that means
BETWEEN +26 and +40... and the LESS positive (towards +26) the wider out the wheel will sit; the MORE positive (towards +40) the further in the wheel will sit from the guard. So if you are running narrower rims (eg 17x7s) but want the look to be wider out near the guard - get your 17x7s with a lower offset (+26).
They said that 8" to 8.5" wide rims SHOULD fit easily within that offset range, but with 18x9s you can get them in but its starts to get more and more precise as to what offset you need as to whether they need to move more positive (away from gaurd) or less positive (out toward the gaurd) to avoid either inside or guard rubbing depending which side there's more room. Which is why itd be nice to know exactly what offset your 18x9s are Gary so we know for sure what offset doesnt rub!??
They also confirmed that they advise NOT to fit different width rims front and back on 4WD Atezza system as the system will misinterpret that slight difference in traction (however on this point id still like some more opinions from tuning specialists).
Thanks guys
its the best explantion iv`e come across.....write a book ."wheel offset shite for dummys"..it becoming a bit clearer for me ..i have different offset front +30/ rear +20 and clearance needed for brembo calipers...bit of a headache really but + or _6/7 is something to start with..thankx for your research Brazen
Hi guys, I have heard this stuff about "damaging suspension because of different wheel offsets" for years. But I have never seen any evidence of it, so it warrants some investigation.....
The basis of this "damaging" claim is the that the centre of contact of the tyre is in a different position to that intended by the designer of the car. So the the first thing to do is find out all of the different ofsets of wheels used with that suspension system. That means what are all of the standard offssets for GTS, GTST, GTR, GTS4 in each model range and for all std wheel sizes, 15" 16 " 17" etc. Looking at the R33 standard offsets I have seen, I can say 30 mm to 42 mm was available. Add the 6 mm tolerance to that and you have 24 mm to 48 mm.
Then we have the issue of camber, if I add negative camber I move the contact patch inwards. This means I can run wheels with more positive offset. A quick measurement shows about 3 mm for 1 degree negative, so that means I can go to 51 mm offset if I run 1.5 degrees negative (my usual road amount).
Now we have caster, if I add 2 degrees of positive caster that means I have say another 2 degrees of negative camber on the outside wheel when I am going around corners. That means another 6 mm of offset, so I can go to 57 mm offset if I run that extra caster.
Now I could get into scrub radius and SAI, but I think I have made the point.
If the wheel fits inside the standard guard and doesn't rub on anything, I don't believe for one instant it would cause one micron of extra suspension wear.
Heavier wheels, lower profile tyres, stiffer springs, stickier tyres, upgraded stabiliser bars. more camber, more caster etc etc would have a much larger effect than wheel offset.
My 20 cents worth:cheers:
I agrre with SK, but your wheels should be all the same if the vehicle is 4wd. The damage is not to suspension but to the gearbox.
Cheers
Gary
P.S. The wheels are coming off in a couple of days for the brake upgrade so i will try and measure the offset then....
There is absolutely no doubt that the circumference of the tyres should be very close to the same front and rear. I say "very close" because there has to be some allowance for wear, otherwise it would be necessary to buy 4 tyres all at once, alll of the time. This applies equally to cars with LSD's, the tyres on the same axle should have the same circumference. But it don't think the width of the tyres makes any difference to the ATTESSA system. Nor do I think wheel offsett is relevant either.
It is worth noting that the same size tyre from different tyre manufacturers can have differing circumferences ie; a 245/40/17 from Yokohama is different to a 245/40/17 from Hancook.
what is the stock rim and trye sizes on a Stagea? Im in SA, so we are only allowed to go 2" bigger in rim size legally. Only reason I ask is that I dont want to buy one with nice mags and then have to sell them cause they are illegal, as Ive seen a few advertised with 18-19" rims.
Is the standard 15" or 16"?
Thanks Gary - be great to know... thats the one bit of info I am hanging out for most...
I would be most greatful to ANYONE who can confirm what offset ranges can fit 18 x 9 inch rims inside the Stagea front wheelarch!!!!!!!
If we can confirm that we will know if GTR rims fit in, or any brandname 18x9 we'll know what offset we need exactly :rofl: Someone must have a mate with a GTR that can do a quick test of fit at the front by swapping a wheel over :)
GTR wheels *will* fit on a Gtst, so they *should* fit on a stag - i might try it with my mates GTR before he sells it.
i just put R34 GTT rims on my stag, looks so much better and fits beautifully.
Looks good Prank. I put a set of GTT rims on mine when I got it (I had them sitting in the shed to go on the R33 before it went to heaven :rofl: ).
I think if we had both our cars side by side we'd have problems telling who's is who's !!
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
