  • Replies 75
Right...did you want to know specifically which wheels from the Nissan range will fit?
There is a HyperRev issue in fact 2 for the Stagea which also looks at what kind of wheels you can fit to the Stagea. Unfortunately there isn't much in terms of tuning, as they are pretty much the same as Skylines...engine wise. If I happen to go pass a newagent I can take a squizz for you, anything specific you wanted to know about the wheels specs?
I'll take any info you can dig up, thanks :P
Thanks Duncan, I wonder if they will let me drive it around with a few sets of loan wheels and tyres for a couple of days each? Just to make sure they don't rub anywhere and that the handlig feels OK, they don't make lots of noise, some tyres simply don't work on some cars etc. :)
The clearance testing may be tricky though, because I won't have set the heights up and maybe not upgraded the brakes. Golly, gosh I would hate to buy a set of wheels that fitted today and then find when I lowered it and put the bigger brakes on those nice new wheels didn't fit. :thumbdwn:
I'll bet that would never happen.......... :jk:
one of the guys on SWAT reccomends...
フロントが235/45/17 8J オフセット+45
リアが235/45/17 9J オフセット+44です。
or should I say,
Front: 235/45/17 by 8". Offset +45
Rear: 235/45/17 by 9". Offset +44
Also... one of the other guys on their bbs runs...
Summer
Front: WORK VS-SS 18 by 7.5 +15 225/40
Rear: BBS LM 18 by 8" +38 FALKEN ZIEGS 235/40
Winter:
SSR integral 17 by 9" +38 MZ03 235/45
When using the 17's he uses 20mm spacers at the front and 26mm spacers at the back
Extreme Winter:
MT-14 15 by 6.5" +38
26mm spacers all around
Do the RS260's run different offset than the RS FOUR versions?
Seems like there are a few fairly different offset specs flying around this thread!
I pick up my 260 tomorrow..it has genuine autech wheels will find out then
saw the car today at the docks......just waved at it ...fark :pissed:
Had a look at what Rays reccomend with their wheels and got this:
STAGEA WC34 1670 +33 205/55R16 1670 +33 205/55R16
STAGEA WC34 1785 +30 225/45R17 1785 +30 225/45R17
STAGEA WC34 1885 +30 225/40R18 1885 +30 225/40R18
STAGEA C34 1780 +38 225/45R17 1780 +38 225/45R17
STAGEA C34 1880 +32 225/40R18 1880 +32 225/40R18
Am I reading this right, the widest tyre is a 225? :headspin:
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
