  • Replies 75
by the looks of it Jake you may need to roll the guards a bit to get +16 wheels under!
dave
i don`t think + 16 have a chance on the front ....all though +18 +20..seems to be number for 260te37
and 250/260
ill try my wheels tomorrow...might end up having a set of lm gt2 for sale ..ex justin fox
Hey Sydneykid,
Just looking at your front bar, looks very different to mine. What year and spec is your Staj??
Ken
Hi Ken, the build date was February 1997 and it's a base model, no woodgrain, no sunroof/s, no sat nav or TV. I picked this one because of the front bumper and headlight design and the blue colour.
It needs shocks real bad and it was owned by a smoker (not usual for Japan) so it reaks. But nothing that 2 days with the steam cleaner won't fix. A couple of days geting the scratches polished and/or touched up and the LHS rear (white door) painted, then it will be ready for rego. Add 1 tow bar and away we go. :cool:
Hahaha, the foot brake still freaks me out when I use it !!
This weekend I'll be able to confirm if R34 GTT mags fit and clear everthing, I'll grab some pics as well just so you can see how/if the fill the gaurds etc..
SK - (a bit off topic), how did your fabricator go with making up a tow bar ? I'd be keen to buy one if it doesn't cost an arm and a leg.
J
well +16 offset stick out too far ...unless i buy some overfenders.(flares).ie:
http://www.freeway-dolphin.co.jp/photo_g/ito/005st.jpg
then i`m making the car fit the wheels ...doesn`t seem right really ...allthough i like look of the small flares ..finishes off the body kit..:confused:
plan b: DAVE send me some details on 18 x9 +20 you can get please ... rays prefered thx
SK - (a bit off topic), how did your fabricator go with making up a tow bar ? ย I'd be keen to buy one if it doesn't cost an arm and a leg.
J
The Stagea is still in the panel shop and I haven't had a chance to get the tow bar measured up. We had a hectic few weeks of racing, one car dropped a diff, it was on the way out, no loss. Another copped a severe over rev (14,000 rpm +) due to a missed shift and another blew a head gasket (no, I didn't assemble that engine). Thankfully the other 2 ran like clockwork all weekend. :wassup:
I you want, I will ask how much to make 2 both at the same time. I can then send it down or you can pop up and get it fitted. Anyone else want a 2.2 tonne capable tow bar? Maybe a group buy chance here. :(
Jeff at C-RED knows what fits and what dosent, I am looking at putting 19 inch Budnik's on http://www.budnik.com/techInfo.asp you can find the way to work out the exact wheel size you can use for any brand on any car.
Wheels are from http://www.ziggyshotrods.com in NSW, 19 inch BILLET'S.
I you want, I will ask how much to make 2 both at the same time. ย I can then send it down or you can pop up and get it fitted. ย Anyone else want a 2.2 tonne capable tow bar? ย Maybe a group buy chance here. :D
Sounds good. 2.2 tonne is a damn big one !! I was looking at something around the 1.5 max, but I suppose it won't matter ;) I'd be interested in what sort of $$$ he can do one for fitted and also unfitted. Funds are slowly running out after buying the car ;)
Thanks
J
There seems to be 2 specs of tow bars these days, one around 1.2 tonnes for box trailers, bike trailers, tinnies and the like. Then there is the big one around 2.2 tonnes for car trailers, caravans and big boats. More info next week inc prices when I get a chance to get ours registered.
    • Good news!!! Changed the O ring today and Iโ€™ve got the โ€œpssshhhhโ€ back when I open the fuel cap ๐Ÿ˜‚๐Ÿ™Œ๐Ÿผ๐Ÿ™Œ๐Ÿผ It was 100% the O ring because that bloody thing was inside the fuel tank ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚ Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But sheโ€™s running!!! โค๏ธ
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though egย https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
ร—
ร—
