So my rb is finally having more problems. 2 issues here but I'm here to just to mainly discuss the rattle noise.
The other day when I turned on the car and when I take off or go in reverse, there is a temporary rattle noise but when I cruise, boost, idle it's completely fine no rattle whatsoever. I've also done all the servicing, all the health checks you can think of and it all passes with flying colours.
Also the rattle doesn't increase with rpm, it's only at a very certain rpm (slightly above 1,100rpm). My other car also has the same issue every once in a while. Changed the oil recently, no difference.
Even took my oil to a lab and everything was quite good surprisingly. Timing belt changed a while ago to. Had the car on the hoist and can't see anything obvious. Tightened a couple of nuts on the exhaust manifold a couple of months ago.
2 different clips uploaded. One of them was supposed to another issue but I'll save that for another time.
Thought I'd see if anyone had this same noise before, it's a bit hard to diagnose while it's intermittent.
If I'm not mistaken, I think I had this a while back but can't remember exactly.
I was thinking if it's doable I'll get someone to hold the throttle cable at 1,100rpm and hopefully it replicates the sound.
rb25det rattle only.mp4
rb25det slow start + rattle.mp4
