i'v posted thread befor about the coils
missfiring @ idle
i use to have it mostly when the car is cold ..
i'v changed the places of the coils ... mmm feel some diffrent .. ( dont know why )
now it miss fire lil bet ... but .. mostly .. it like losing power btween 4500 tell 5800 exactly .. only between those rev its not accelerating like it should ... after 5800 rev . it go's ok ... tell it reach 7000 ... every time it did the same .. in all gears .. (didnt try 5th gear) and by the way .. it happen some times .. some times it not ... i mean after driving for some time .. this gos off
any way
100% misfiring at idle .. but not sure if it misfire at 4500 .... (i think its somthing else)
so .. the Q is .. ?
why its only loosing power at 4500 to 5800 every time ????
is there anything special happen between those rev's ??
i really feel sick already :throwup:
plzzz help
if they r the coils that would be easy to fix ..
mod: hks filter only
https://www.sau.com.au/forums/topic/46618-sick/
My friends car misfired between 4000rpm and 6500rpm because the spark plugs where gapped to high, we gapped them down and it was all good. Maybe check your plugs first.
...thanx for replying mate ....
i already did that ..
gap = 0.8
NGKplug IR laser iredum
heat range 6
i'v also tryed NGK R iredum
heat range 5
also did compretion ratio at home ..... its ok... lil diffrent in some of them .. (not a big deal tho)
some pic
https://www.sau.com.au/forums/topic/46618-sick/#findComment-945623
Considering your mods, that is quite strange.
With most RB25DET's running higher than stock boost, the reason there is a flat spot in this rev range is b/c of the A/F ratio's getting very rich. Timing is also retarded at this point. If your coils have any fractures in the casing, it will also misfire.
Best solution is aftermarket management or a SAFC to correct the fule mixtures.
There are quite a few threads covering this topic, search around and you will find a few solutions that have worked for others in the past...
Zahos
https://www.sau.com.au/forums/topic/46618-sick/#findComment-945658
Zahos
thnx mate .. that makes me happy ..(coz i wanna belive that its only the coil :D )... if its only coils that would be ok .. i'll change the coils next month ... split fire coils or should i go for those kind of coils which comes away from the engin (check pic)
and going for powerFC soon ,.
if any one else have any other thoughts ... iwould like to know more ... thanxx guys ..
https://www.sau.com.au/forums/topic/46618-sick/#findComment-945701
or it could be anything, some one correct me if im wrong.
steve
mm .. the problem is that it comes and gos ..
so .. still not sure .... but 100% i'd go for new coils ... but no one answered my Q .. ?!
do i go for split fire coils ....
or i go for this coils which come alone away from the plugs ... the one on the pic .. i posted befor ...
thanx
https://www.sau.com.au/forums/topic/46618-sick/#findComment-950522
why are they 2 different spark plugs?
One is NGK IR, the other is just R. I would definately replace those plugs just from the look of them.
Gapping iridiums is ok, you just have to be carefull. The most important part is the tip, the rest is fairly durable.
Also, how tight have u put the spark plugs in?
Try insulating the coils with electrical tape aswell
https://www.sau.com.au/forums/topic/46618-sick/#findComment-951203
I would recomend the coils that are on the firewall (the ones in your pic) as the skyline coils are prone to failure as they get so hot!
i like that idea .... but .. do u know any good coils which is ok for the r34 .. and what convertion do i have to do to the ignition wireing .. ??
that would be a good info .. :)
thnx
https://www.sau.com.au/forums/topic/46618-sick/#findComment-951432
i know ... i did test the NGK R 1st ... then i'v checked the NGK IR ..
i will change them also .. while changing the coils .. ..
any info about the coils in the pic .... :) .. ?!
https://www.sau.com.au/forums/topic/46618-sick/#findComment-951436
i dont know ... exactly ... but 100% not too tight ... i can open them and close them easly .. but i know they r not lose ..
https://www.sau.com.au/forums/topic/46618-sick/#findComment-951440
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
