i'v posted thread befor about the coils
missfiring @ idle
i use to have it mostly when the car is cold ..
i'v changed the places of the coils ... mmm feel some diffrent .. ( dont know why )
now it miss fire lil bet ... but .. mostly .. it like losing power btween 4500 tell 5800 exactly .. only between those rev its not accelerating like it should ... after 5800 rev . it go's ok ... tell it reach 7000 ... every time it did the same .. in all gears .. (didnt try 5th gear) and by the way .. it happen some times .. some times it not ... i mean after driving for some time .. this gos off
any way
100% misfiring at idle .. but not sure if it misfire at 4500 .... (i think its somthing else)
so .. the Q is .. ?
why its only loosing power at 4500 to 5800 every time ????
is there anything special happen between those rev's ??
i really feel sick already :throwup:
plzzz help
if they r the coils that would be easy to fix ..
mod: hks filter only
https://www.sau.com.au/forums/topic/46618-sick/
My friends car misfired between 4000rpm and 6500rpm because the spark plugs where gapped to high, we gapped them down and it was all good. Maybe check your plugs first.
...thanx for replying mate ....
i already did that ..
gap = 0.8
NGKplug IR laser iredum
heat range 6
i'v also tryed NGK R iredum
heat range 5
also did compretion ratio at home ..... its ok... lil diffrent in some of them .. (not a big deal tho)
some pic
https://www.sau.com.au/forums/topic/46618-sick/#findComment-945623
Considering your mods, that is quite strange.
With most RB25DET's running higher than stock boost, the reason there is a flat spot in this rev range is b/c of the A/F ratio's getting very rich. Timing is also retarded at this point. If your coils have any fractures in the casing, it will also misfire.
Best solution is aftermarket management or a SAFC to correct the fule mixtures.
There are quite a few threads covering this topic, search around and you will find a few solutions that have worked for others in the past...
Zahos
https://www.sau.com.au/forums/topic/46618-sick/#findComment-945658
Zahos
thnx mate .. that makes me happy ..(coz i wanna belive that its only the coil :D )... if its only coils that would be ok .. i'll change the coils next month ... split fire coils or should i go for those kind of coils which comes away from the engin (check pic)
and going for powerFC soon ,.
if any one else have any other thoughts ... iwould like to know more ... thanxx guys ..
https://www.sau.com.au/forums/topic/46618-sick/#findComment-945701
or it could be anything, some one correct me if im wrong.
steve
mm .. the problem is that it comes and gos ..
so .. still not sure .... but 100% i'd go for new coils ... but no one answered my Q .. ?!
do i go for split fire coils ....
or i go for this coils which come alone away from the plugs ... the one on the pic .. i posted befor ...
thanx
https://www.sau.com.au/forums/topic/46618-sick/#findComment-950522
why are they 2 different spark plugs?
One is NGK IR, the other is just R. I would definately replace those plugs just from the look of them.
Gapping iridiums is ok, you just have to be carefull. The most important part is the tip, the rest is fairly durable.
Also, how tight have u put the spark plugs in?
Try insulating the coils with electrical tape aswell
https://www.sau.com.au/forums/topic/46618-sick/#findComment-951203
I would recomend the coils that are on the firewall (the ones in your pic) as the skyline coils are prone to failure as they get so hot!
i like that idea .... but .. do u know any good coils which is ok for the r34 .. and what convertion do i have to do to the ignition wireing .. ??
that would be a good info .. :)
thnx
https://www.sau.com.au/forums/topic/46618-sick/#findComment-951432
i know ... i did test the NGK R 1st ... then i'v checked the NGK IR ..
i will change them also .. while changing the coils .. ..
any info about the coils in the pic .... :) .. ?!
https://www.sau.com.au/forums/topic/46618-sick/#findComment-951436
i dont know ... exactly ... but 100% not too tight ... i can open them and close them easly .. but i know they r not lose ..
https://www.sau.com.au/forums/topic/46618-sick/#findComment-951440
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
