I'm in the process of changing the front wheel bearings on my ecr33 Skyline and I notice in the manual there is no torque spec for the big 32 mm nut that holds the spindle / hub assembly onto the knuckle . In fact , in the FSM I don't even see the that specific bolt in the part breakdown. I notice that the nut was punched on the edges to secure on the stud it threads on so i'm not sure if I just seat it properly and punch it or if it has to be set to a specific torque.
the picture below will give you a Idea of the Nut i'm talking about if my explanation is unclear. i know its a rear hub and not from a skyline but its to give you a idea of the nut i'm talking about
Any help would be greatly appreciated , Thanks !
1 hour ago, GTSBoy said:
There's not really a torque setting.  These things are done up to a "feel".
Thanks for the reply GTSBoy - I ended up calling a buddy that looked in a USDM shop manual on his computer at work. Since its the same bearing as a 300z I assume its the same torque spec. The manual listed a torque of 200Ft/lbs so I wont take any change and follow the FSM as both have same bearing and setup according to the part breakdown
yeah but this is for a 2wd not 4wd as the 4wd bearing is held by the nut at the end of the driveshaft, so GTR manual not helpful
When you can't find a specific torque work from the diameter of the bolt/stud it is going on, 200ft/lb is about right for an M18 bolt assuming 8.8 strength
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
